Hi all, I know there's info on the site re: capturing in general and specific info on converting SWF files to video, but so far I've had no luck in this particular case.
I have a swf video that has a "click to start" intro that prevents proper conversion. Furthermore, it's protected so I can't remove the intro. I've tried doing a screen recording using Snagit, but it will only record the video, even though I have it set to record audio as well.
Does anyone have a workaround for this? Maybe a better screen capture app?
BTW, the resulting AVI will be just for my personal use, not distro. I want to add it to a collection of videos on a DVD that I coud then play, instead of having to switch to IE just to view the swf video.
Thanks!
You can use Audacity to capture the sound. It's free and easy to use. You'll then have to sync the sound with the video. You can use any video editor for that.
I stand up next a mountain and chop it down with the ledge of my hand........ I'm a Voodoo child.... Jimi Hendrix,
How to convert a DVD (video) to swf file?
By nkamp in forum DVD RippingReplies: 1Last Post: 6th Jan 2011, 11:08 -
No sound when capturing video ???
By j4mes_bond25 in forum Capturing and VCRReplies: 6Last Post: 10th Aug 2009, 12:03 -
Capturing SWF Stream, Results in Taunting Server Admin Video
By smartwhois in forum Video Streaming DownloadingReplies: 1Last Post: 27th Jun 2008, 12:31 -
SWF mx, swf 3 ( legacy ), and FLV, whats the difference
By theewizard in forum Newbie / General discussionsReplies: 3Last Post: 5th Feb 2008, 00:15 -
Having trouble capturing an .swf file...
By Captain Satellite in forum Newbie / General discussionsReplies: 3Last Post: 9th Aug 2007, 07:54
