    Jul 2005
    Italy
    Hi!
    Is it possible to open a frameserved file (virtualdub) with a media player directly without encoding it?
    I tried to open *.vdr file with media player classics but i reiceve an error.
    Instead tmpgenc open it with no problems..
    Thanks!
  2. Media Player Classic will give you error simply because it is not designed to read a vdr file.
    A vdr file is a dummy / temporary file used for frameserving audio & video streams to an encoder application like TMPGEnc. Frameserving is used generally when the encoder app does not recognise a particular audio / video stream. This avoid compatibility issues.
    When I was born I was so shocked that I could'nt speak for 18 months.
    Jul 2005
    Italy
    Yes I know.
    I just wanna know if it's possible apply vdub filters > frameserve > see result in a media player..
    Why would you want to do this?
    You want to apply filters/resize whatever and view it on the fly?
    Jul 2005
    Italy
    Exactly..I need to apply some filters and view it on the fly.
    I see that in vdub i can see it on the fly, but i can't see the video in full screen..so i wanna frameserve to a media player.
