  1. I have 4 questions about ripping / burning:
    1. What, if any, are the real differences between burning an iso with Imgburn and DVD Decrypter?
    2. Is there any way to get DVD Shrink to use Imgburn instead of DVD Decrypter (automatically)?
    3. If you use DVD43 to get past the “protection” to backup a DVD, would there be any significant difference between the iso created by DVD Decrypter, DVDFab Decrypter, or DVD Shrink (assuming no compression)?
    4. Would FixVTS be used before shrinking, after shrinking, or both?
    Thanks for any replys.
  2. 1. None
    2. No, because Shrink is no longer updated.
    3. There would be no difference assuming the software used in conjunction with dvd43 is still able to rip the dvd.
    4. It would depend on whether shrink could or could not handle the file in the first place. If shrink has a problem with the file, you would then use fixvts and then attempt to use shrink again.
    I am Jack's medulla oblongata
