I'm looking for something that will cut out the first 1:07 and the last 0:36 from an avi. I have about 2000 of these and going through by hand would take forever. Eventually, I want to re-compress using ffmpegx into ipod H.264. Note that the time lengths vary +/- 30 seconds, so I cant say cut between 1:07 and 19:29. I just need the last 36 seconds removed. Any ideas?
MPEG Streamclip will do this. It may not give you the same quality (YMMV, as they say) but it's worth a shot. The app is free.
Yes, I had noticed before that mpegstream clip has an excellent batch processor, and that was actually the ipod h.264 batch'er I was going to use. Unfortunately, I need to cut the intro and credits and that isn't one of the options to batch.
Thanks for the suggestion though!
It appears that you will have to go through each of the 2000 avi's individually so that you can set the "in" and "out" points, right? If so, why not open the avi in QT Player, select the part of the movie you want to keep, copy, open a new QT Player window, paste, and "save as" a reference movie? (This is not an "export" which would take a long time.) Once you have all of the reference movies saved, drop them into MPEG Streamclip. It's perfectly happy to work with QT reference movies.
Note that you might need QT Pro in order to do the "save as" I suggest.
Let us know if this does the trick.
virtualdub: Cutting video in batch mode?
By zzyzx2 in forum EditingReplies: 2Last Post: 21st May 2010, 14:18 -
How to Batch Process Using Avidemux? Or Batch Processing H264 .m2ts or .ts?
By forgotpassword in forum Video ConversionReplies: 0Last Post: 14th Apr 2009, 00:00 -
Cutting VOB File without any quality loss? (ending credits)
By willhenderson in forum Newbie / General discussionsReplies: 10Last Post: 15th Oct 2008, 22:45 -
Remove intro and Credits from a MKV File
By andrema71 in forum EditingReplies: 1Last Post: 15th Jun 2008, 10:08 -
Logos in Credits
By ehmjay in forum MacReplies: 6Last Post: 13th Sep 2007, 21:27
