I have tried IFOedit on a DVDshrink ripped DVD and have the following question. The tutorial for IFOedit says that when cliking on "Create IFO" i should pick the first video vob. I thought that to be VIDEO_TS.vob, but this file was rejected and I had to select VTS_01_0.vob instead. I think i now have understand that this must be because that VIDEO_TS.vob is not a video file but a menue. But, when IfoEdit was finished, it had also created a VIDE_TS.ifo together with the VTS_01_0.ifo, and this I do not understand. Have you any shortform tutorials which will cleare up my minde a byte.
Thanks in advance
What is it you are trying to do exactly?
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
umm ... yeah. What he saidOriginally Posted by sacajaweeda
The point of the "Create IFO" button in IFOEdit is to take one title and make a fully playable-on-insert movie-only DVD out of it. In order to do this, it needs not only to create VTS_01_0.IFO/BUP, but also VIDEO_TS.IFO/BUP since it is these latter two files that tell your DVD player to go straight to the main movie.If in doubt, Google it. -
Hmm, I have no clue! I guess I wanted to create ifo from existing Vob files and then use some tools to burn it to a DVD±R disc like "Burn My Files" which have the option to burn the files in DVD file format or watever it is, (i.e. i can choose to burn files using diferent ISO standards, UDF and DVD file system) I dont expect "Burn My Files" to create ifo files when I only have the vob files aviable and thus needed some tools to create them for me like IFOedit.
There is quite many thing about the DVD file system I do not understand and the ... ah I youst remember, I have heard somewere that the VIDEO_TS.vob file is mostly info and copyright notices, not menues as I belived some houres ago, dont need that so i skip it. Never mind. However, while thinking a little byte aboute, MUST there always be a VIDEO_TS.vob in every VIDEO_TS directory anyway??? As far as I know and understand is that if i use IFOedit to create ifo files from exsisting vob files i can be able to burn DVDs by using "burn my files" in DVD mode. But I then run into another problem, the vob files i have is diverted into several chapters like VTS_01_nn.vob and VTS_02_nn.vob and so on. I was only able to create new ifo's for the first chapter, how come? When trying to create ifo, s for chapter 2 into the very same folder, it seems to work (i.e. IFOedit works) but no new ifo files is added to my directory, and I cant find them any other places either.
Then another question comes to my mind, if using dvd shrink or decrypter to rip a DVD with ifo files and BUP and burps, should I then be able to burn these files with success into DVD file format without needing to do some extra stuff with my backup? I mean the DVD ifo files ripped is intact and readable by a standalon livingroom dvd player, ayie?
Many questions you think?? Good, then you will not get bored,, and thanks for taking time to answer
Regards
Z
ffmpeg CPU usage
By diprotic in forum Video ConversionReplies: 13Last Post: 19th Apr 2015, 15:40 -
Runaway PF usage
By JudgeGarth in forum ComputerReplies: 7Last Post: 1st Feb 2009, 18:35 -
internet usage
By d_unbeliever in forum ComputerReplies: 10Last Post: 17th Apr 2008, 11:54 -
CPU usage goes to 100%
By Tbag in forum ComputerReplies: 21Last Post: 18th Jan 2008, 10:59 -
Usage of DirectDvd ???
By hulinning in forum Software PlayingReplies: 1Last Post: 28th Nov 2007, 10:51
