SageTV creates mpg2 files at low compression rates. For me it's about 4GB per hour so for a 30minute clip I want to email, I still end up at 1GB which is way too large. How can I get the highest possible compression for this file and what is the best software to use to do that?
car audio woes
Virtualdubmod or Windows Movie Maker.
Open the mpg, select your compression codec, and let it run.
For email, WMM would be better.Cheers, Jim
My DVDLab Guides -
Excellent... Will try. Thank you.Originally Posted by rebootcar audio woes
Best compression, smallest size, highest quality?
By Sullah in forum Video ConversionReplies: 17Last Post: 12th Nov 2022, 11:48 -
Control of Cable box via SageTV on Windows Media Center 2005
By Sierraguy in forum Media Center PC / MediaCentersReplies: 2Last Post: 8th Feb 2010, 02:31 -
merge / join 2 MPG2 files
By joelore in forum Newbie / General discussionsReplies: 4Last Post: 21st Jun 2008, 23:14 -
plan for converting SageTV mpg's to smaller files.
By Verlager in forum LinuxReplies: 7Last Post: 6th Feb 2008, 23:56 -
Highest Compression Codec?
By Solonor in forum Newbie / General discussionsReplies: 7Last Post: 27th Dec 2007, 18:40
