Hi, I was just using DJRumpy's guide (https://www.videohelp.com/forum/viewtopic.php?t=222898) to convert xvid avi files to mpeg2 files to record to DVD.
I've been able to do everything correctly so far and right now, as I write, TMPGEnc is converting the file. The only problem, my audio was about half a second fast in the first place. I don't know how to fix that.
Should I have fixed that first, before the conversion? Can I still fix it afterwards? And even worse, I just joined to xvid avi's and the sound COULD have been out of sync differently on both of those files.
Any suggestions?
Signed, a novice who looks like he knows what he is doing, but is in way over his head....![]()
Virtualdub, Audio>interleaving>audio skew correction.Originally Posted by jemmanben
You should have done that first, I don't know any good ways to do it after.
Joining files can cause sync problems, it's usually better to just let the authoring program "join" your clips."Art is making something out of nothing and selling it." - Frank Zappa -
Use Virtualdub to demux the Video (Direct Stream copy) to a new AVI file. Demux Audio (Full Processing) to wav format. Mux the new video and audio wav file. Then encode this new file with TMPGEnc.
If the AVI file is 23.97fps, set your encoder to 29.97fps.
Converting Xvid AVI to DVD
By rocks911 in forum Video ConversionReplies: 2Last Post: 21st Aug 2011, 20:24 -
Converting 25fps XVID to 29.97 MPEG2
By dkrajisnik in forum Video ConversionReplies: 6Last Post: 21st Sep 2010, 15:46 -
Why does XVID avi file balloon in size when converting to mpeg2 or dvd?
By im2020 in forum Video ConversionReplies: 3Last Post: 11th Aug 2010, 13:30 -
converting Dv-Avi/Dvd Mpeg2 to Xvid format
By glenpinn in forum Video ConversionReplies: 56Last Post: 9th Jun 2009, 10:23 -
Converting Xvid avi's to dvd always fail
By sosnowski in forum ffmpegX general discussionReplies: 2Last Post: 6th Nov 2008, 16:36
