Hi guys,
I am from Australia and need some advice on selecting a cheap dvd player that can play divx/xvid and MP3.
So far i have narrowed my selection to the following:
Nintaus n9808
Phillips DVP 642
Tevion DVD-4000
XMS- 888
I would like some advice on the above players. Which one would you buy?
Secondly if someone knows where i can buy the player in australia, preferablly online, please let me know also.
Thankyou.
Results 1 to 9 of 9
XMS-888 is abit old
look at the Z340
http://www.zensonic.com.au/z340.php -
looks good, although it is above my budget.Originally Posted by Sifaga
whats your budget, where in oz are you
$121 from here http://www.megapc.com.au/product_details_and_order.php?select_part_indx=4091 -
I live in Wagga. My budget is $100 at the moment. How does the Z340 compare to one of the more popular and cheaper models such as the DVP 642?
I have the Philips DVP-642 here in America and I like it. However, it has a lot of fans and detractors. It seems that Philips quality control is really bad on this model and some (like mine) work fine and others very quickly develop serious problems. This player is very thin and thin players tend to "run hot", so if you buy any small and/or thin player, be sure to put them in a place with open space and good ventitlation or heat will shorten your player's life.
The DVP-642 can be made multi-region via the remote control and it plays DivX. Some people are just in-your-face adamant that the picture on the DVP-642 is TERRIBLE, but some of us disagree. One guy said "OK, it's terrible only if you play it on an HDTV, but it's OK otherwise". Since I don't have an HDTV, I can't check that.
Finally, this may not be important to you at all, but the player is very fussy about SVCD discs. It will only play the first audio channel on an SVCD, although the format supports 2 separate audio channels, and if your SVCD has subtitles, it will only play the first one and it CAN'T BE TURNED OFF
whats the difference between the zensonic z330 and z340?
And how do they handle the use of subtitles? -
My 642 looks wonderful on my analog Philips 25"
I have been into computers since 1980. Ive been tinkering with DV in one flavor or another since 1990.
Need help selection BD player
By music5_5 in forum DVD & Blu-ray PlayersReplies: 7Last Post: 11th Sep 2011, 22:29 -
USB Media Player with direct selection of file (picture) by number
By Safer63 in forum Media Center PC / MediaCentersReplies: 0Last Post: 11th May 2011, 19:45 -
Want to put the dvd in my dvd player and it plays, no frame selection.
By LauraSpring in forum Newbie / General discussionsReplies: 3Last Post: 15th Nov 2009, 18:29 -
DVD Styler & Scene Selection
By TheKidUn in forum Authoring (DVD)Replies: 0Last Post: 14th Jan 2009, 21:49 -
Portable DVD Player selection (if you own one please give your comments)
By kramer in forum DVD & Blu-ray PlayersReplies: 1Last Post: 9th May 2007, 13:44
