What's the best way to do the above?
Would it not be wise to convert the .mov to mpeg2 and then divx? If that's an alright option, is there a free tool to do that - .mov to mpeg2?
There are some Free Encoders here https://www.videohelp.com/tools?s=40#40
You are better off Encoding Right to Divx. -
yea, if at all possible, your always best to keep the number of conversions to a minimal......as for mov to divx, tmpegenc can do that with the quicktime plugin...just follow the quicktime plugin's instructions and then just open the mov file then go file>output>avi and it will come up with a new window that you can configure your video to divx/xvid/whatever else you want....
It's encoding to .avi (what's that - not divx?). Are you saying after that I'll get another choice - divx, xvid, what have you...?Originally Posted by whitejremiah
Wow, it went from 49mb to a 2+gb .avi - trying to the other way
Is DivX avi is better than flv, wmv, and mov?
By dread in forum Newbie / General discussionsReplies: 12Last Post: 20th Apr 2011, 12:38 -
Converting AVI (DivX/XviD) to MP4/MOV/3GP...
By JaleAlbatros in forum Video ConversionReplies: 5Last Post: 23rd Jul 2009, 18:51 -
I use TMpgEnc to convert MOV to DIVX. But the quality of AVI isn't good
By natong in forum Video ConversionReplies: 0Last Post: 11th Apr 2009, 01:21 -
Converting HD (DivX/MOV/WMV etc) to DVD or DivX ???
By snadge in forum Video ConversionReplies: 32Last Post: 8th Jan 2008, 06:48 -
MP4 files in MOV format - how to play in dvd/divx player
By glen_s in forum Newbie / General discussionsReplies: 1Last Post: 24th Nov 2007, 04:49
