I rip subtitle from dvd, i have subtitle for divx movie. They are not synchronize properly. What is the best way synch my divx subs to my dvd ?
Thank you
bye
Hi-
Are they off by the same amount all the way through? Then it's an easy matter to adjust the delay. There are several ways to do this, but I'd convert them to SSA first, using Resynch (comes with the VobSub package), open the SSA subs in SubStation Alpha, and at the top, go Timing->Shift Times and adjust the times.
If you have a progressive delay (gets worse as the video goes along), then maybe your subs are PAL and the video is NTSC or vice versa. In that case you can adjust the framerate in SubCutter (also in the VobSub package). If the subs are timed badly, and there's no pattern to the asynch, then you have your work cut out for you, and I'd go and look around for some better subs.
divx subtitle to dvd?
By uniks in forum Newbie / General discussionsReplies: 6Last Post: 18th Sep 2009, 18:29 -
Would synch mostly occur on DVD to DivX, or XviD to DivX?
By rocky12 in forum Newbie / General discussionsReplies: 3Last Post: 29th Oct 2008, 02:01 -
Divx subtitle on DVD/Divx player Problem
By abo_shreek11 in forum SubtitleReplies: 4Last Post: 24th Mar 2008, 15:39 -
By abo_shreek11 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 8th Mar 2008, 04:41 -
DIVX DVD Player Audio Synch problem
By wulf109 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 6th Mar 2008, 09:14
