Can anyone help me with converting a 3gp video? Ok I get that the files are supposed to be small - but I'd like to be able to make out the audio.
I am using Xilisoft video converter and I can up the video bitrate so that it looks good, unfortunately it won't allow me to up the audio sample rate from 8000 and so the sound is terrible no matter what bitrate I choose.
I'm not that familiar with the 3GPP and 3GPP2 formats, but I did create a short 3GPP video from a DV-AVI with Quicktime Pro. As you probably know those two formats are primarily for video on cellphones. I just don't think that it is possible to make either the video or the audio any better than it already is. The information is simply not there to make it look or sound better. For example with a 8000 bps sampling rate for audio the frequency response is 0 to 4000 Hz, which should be OK for speech, but there is no treble (high frequency) information. It is impossible to get that treble information if it was never stored in the encoded file. Similar principles exist for the video information. 3GPP and 3GPP2 are extremely lossy compression schemes. Once the data is gone there's no getting it back.
Tools used: ScenalyzerLive 4.0, Adobe Premiere Pro 2.0, Adobe After Effects 7.0 Professional, Adobe Encore DVD 2.0, IFOedit 0.96, DVD-lab PRO 1.53, Adobe Audition 2.0 -
Pre-filtering (with high quality dithering) can help somewhat.
Audio Example:
Source Audio = 16bit, stereo, 48kHz, LPCM ?
0. Mix to Mono.
1. Use Dyn. Range Compressor to get levels w/in ~48dB range, w/ Limiting of major peaks.
2. Use Harmonic Synthesizer to octave double lowest bass ranges (20Hz-80Hz --> 80-320Hz (added/mixed at low level to main signal) (only if really needed)
3. Use Peak EQ filter of ~+3.5db for ~1.2kHz, 1.5octave band
4. Use LowPass(HiCut) filter (w/ high phase linearity--FIR) set to 3950Hz
5. Use HiPass(LowCut) filter (also high PL--FIR) set to 80Hz
6. Use a dithered Normalizing Limiter again to punch everything up to the top of the dyn. range.
7. Apply "Noise Reduction/Smoothing" filter to pre-subtract elements that can be eliminated prior to compression--This is a good way to hear an output similar to what the psychoacoustic masking will be doing in the compression. (use sparingly and with caution)
8. RENDER elements of sound/music/speech inactivity AS digital silence (all zeros). This can help alot!
Now, compress. Use VBR/ABR if you have the option and the playback devices support it. Use the highest quality encoder available.
Similar gains can be done in video as well...(that's for another time).
Hope that makes a difference for you...
edit: Actually "similar loss savings". The idea is: You are directing the loss as opposed to letting the compressor arbitrarily determine the loss, thus sonicly maximizing the available remaining bits. -
You could try SUPER to encode. It works pretty good for 3gp file creation.
Melde Melda Vessė
Eruanna ar Eruntano Melda Eruntanohini
"May your days be bright and contact with stupid people limited." -
Another freebie is the Nokia mulitmedia converter. It's a free download.
ImToo also has a 3gp converter that looks identical to the Xilisoft one.Cheers, Jim
My DVDLab Guides
How to get the best out of .3GP (720p!)?
By VinylCyril in forum Video ConversionReplies: 3Last Post: 17th Feb 2011, 11:54 -
3gp issues
By flyingfrogsss in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2010, 02:40 -
3GP
By begeta50 in forum ffmpegX general discussionReplies: 3Last Post: 16th Aug 2009, 11:15 -
3gp with subtitles
By maxmaxx in forum Video ConversionReplies: 0Last Post: 5th Jan 2009, 17:23 -
FFMPEG 3gp
By dizzy123 in forum EditingReplies: 3Last Post: 6th Sep 2007, 03:24
