Howdy Guys
I was wordering if someone can give me an answer to a strange error that im getting with TMPGE Xpress. It goes like this.
Sometimes the video clips that i encode come in two different parts. Basically I encode avi-mpeg.
That part I have sorted.
The error ocours when I try to join the two resultant mpeg clips together. Basically I load the two resultant video clips into TMPGE and then set output format and so forth unill I get to the screen that gives you the options-
What do you want to do here? "Encode the clips seperately" or "Combine the clips together and output to a common file". I select-
"Output to a common file"
I then press the "Start ouput/encode" Button.
This is where the error occours. It starts analysing the files and for several nano seconds seems ok. I then get a message stating
"There is no quoted number of Character-string '%.2f'."
and then an explanation saying in red "An error stopped the output"
Not being a video expert this is as clear as mud to me. Can someone please explain what is happening here and point me towards enlightenment.
Thanks.
Results 1 to 1 of 1
Can TMPGEnc 4.7.7.307 XPress support output 5.1 Channels???
By JackyWang in forum DVD RippingReplies: 2Last Post: 17th Apr 2011, 23:37 -
Bizarre error using TMPGEnc 4.0 Xpress?
By the colonel in forum Video ConversionReplies: 1Last Post: 29th May 2010, 21:30 -
Tmpgenc Xpress 4 stream reading error
By WinSpecToR in forum Video ConversionReplies: 8Last Post: 16th Oct 2008, 08:50 -
.avs scripts in TMPGE Xpress?
By ecc in forum Video ConversionReplies: 0Last Post: 12th Aug 2008, 08:39 -
Help with output after editing with tmpgenc 4.0 xpress
By uka100 in forum EditingReplies: 2Last Post: 14th May 2008, 21:30
