OK i am new at this, but finally got a dvd movie made of my old home movies. everything works great except for it won fast forward on my Yamaha DV-C660 dvd changer or any other dvd player in the house does fine on the cpu. I used pinnacle studio 10 to capture,edit then went to makemovie and saved to ts_video folder then burnt it on the burner that come with laptop, which is NTI CD & DVD maker. Hopefully this is enough info for someone to help me. By the way I can ff at 4x for like 10 seconds at a time then it stops. If I try to go faster than 4x in goes back to main menu. And dont know why it stops each time after like 10 seconds.
Bad burns and/or bad/cheap media can cause this to happen. Try a different brand/type of media.
Google is your Friend
