Will some one guide me how I can create a vcd from the still image viz., jpg,gif,bmp so that it could be run on any vcd player to watch on Tv.
I use nero5.
Results 1 to 20 of 20
You can first check whether your VCD/DVD player is capable of playing a disk with JPEG images. Most recent playes do support. Because if it does then you dont have to create a VCD.
When I was born I was so shocked that I could'nt speak for 18 months. -
Are you talking--
1. Still pic1 -->CLICK to ADVANCE --> Still pic2, etc.?
or
2. Transitioned and Music-ed, timed slideshow "movie"?
They have 2 completely different ways to create.
Scott -
Hi All,
Sorry to jump in...But Scott, could you elaborate on #2. That is exactly what I want to do. SlideShow with music in the bg.
Don't want to spend a HUGE amount of time on it, so an easy tool would be great!! Is there a tool on this site that I could use? I downloaded the 14 day free trial of Nero 7, but I can't find an option to add music or create a slide show.
Thanks very much!GO SOX AND PATS!!! -
ProShow Gold. (or Ulead Video Studio)
/Mats -
Originally Posted by DingoAce10
1. Load pictures, set duration (I usually use 4-10sec. each)
2. Assemble edit them in (append/concatenate)
3. Add music under, either timed/edited to pic boundaries or simply append them as well
4. Apply transition FX (can usually be done globally as well as individually)
--Don't overdo it here unless it's asked for--
5. Render to 1 long video+audio clip, either as AVI to be converted later to MPEG, or directly encode as MPEG.
6. Author as single title with chapters(?) and Burn.
Notice that only the last step is part of DVD authoring, the rest is Video NLE realm.
Scott -
Thanks for the advice/info!!
Sorry I am a little dumb on the video abbrieviations...What is "NLE"?
THanks again!GO SOX AND PATS!!! -
Non-Linear Editor, aka Video (+Audio) computer-based editing application.
Non-linear here means "random-access" or "file/disc/ram-based", as opposed to Linear (tape-based).
Examples:
AVID Composer / Xpress
Sony Vegas
Adobe Premiere
AVID (formerly Pinnacle) Liquid
Apple FinalCut Pro
Ulead Video Studio
many others...
even VirtualDub and AVISynth are video editors, although they're not set up for extensive, complicated edits.
Some compositing/animation apps such as Adobe AfterEffects, Commotion, Apple Motion can do editing as well, but that's not their forte.
Scott -
Hi Scott,
THanks for the explaination and suggestions. A friend of mine (video editor) said that Avid FreeDV would work, but it is finickie about the PC you run it on..I have had to many problems with my work laptop to try that...He also mention Windows MovieMaker. Have you tried that? Any good?
Thanks!GO SOX AND PATS!!! -
My personal choice would be Mpeg Video Wizard."Art is making something out of nothing and selling it." - Frank Zappa -
WMM can make a slideshow and save as (usually) a WMV file or (occasionally) a DV file. I've used it for DV a number of times--usually when I'm given a WMV by a client and they want a DVD from it--like yesterday!
After loading the media, and editing the timeline, do "SAVE MOVIE FILE".
Choose "My Computer", select location, use "Other settings: DV-AVI (NTSC)" (assuming it's NTSC).
It'll take a while to render.
Then use an MPEG encoder (like TMPGEnc, CCE, Mainconcept, etc) to create an MPEG for VCD or DVD. Looks very good this way. Do similar encoding for AC3 audio (if that's the format you've chosen for audio).
HTH,
edit: I personally don't recommend WMM and use it only when necessary. Mainly 'cuz of it's lack of pro video editor features. I've been spoiled by using AVIDs for the last 10 years. I do like Vegas or Premiere for prosumer stuff, though. -
Thanks all!!
That Memories on TV software looks right up my alley right nowSimple
I am just going to be making a quick thing here for an extra shocking stuffer for my wife...I eventually want to create "keepers" so I will have time to learn those more robust options.
Unless you guys don't like "Memeries On TV"...Again, all I want to do is a pic slide show with music in the background...Nothing spectacular..
Thanks again!
GaryGO SOX AND PATS!!! -
Originally Posted by sanjayk
thanks -
Like I said earlier. If your player supports JPEG images then siimply simply copy them on a CD-R or preferably a CD-RW using Nero and put in your player.
The player will automatically detect the disk and display the images on your TV screen one after the other.When I was born I was so shocked that I could'nt speak for 18 months. -
A very important point nobody has mentioned is that still images on VCD can be at 720x480 resolution, but as soon as transitions are added, resolution is reduced to 352x240.
Yes, a very important point (although it's 704x480/576, not 720). That's why I usually do the user-advanced stills version. I much prefer the resolution/quality and could care less about transitions. And the music, I can take or leave.
Scott -
Originally Posted by Nelson37
/Mats
mpg creating
By nighthawk2018 in forum Newbie / General discussionsReplies: 2Last Post: 18th Dec 2009, 18:23 -
*Creating* AVCHD
By qabi in forum Video ConversionReplies: 2Last Post: 8th Dec 2009, 02:03 -
Error creating VCD
By maruz in forum ffmpegX general discussionReplies: 4Last Post: 17th Oct 2009, 06:42 -
Creating (S)VCD Stills with Audio
By Cornucopia in forum User guidesReplies: 8Last Post: 4th Aug 2007, 12:05 -
Creating Movie
By Adarsh2211 in forum Video ConversionReplies: 2Last Post: 28th May 2007, 22:42
