I have just been trying to copy a few videos onto a dvd using nero Vision to make a dvd for my dvd player. for some reason when i egt to the end of the 40 minute clips the sound seems to be out of sinc with the rest of the video, i cant see why this is cause in avi form they are perfectly fine?
Why why is this, is there any other way i can put them on dvd using any other more reliable software, quickley and easily, they are just needed as quick as possible, as long as they have decent quality i dont mind.
Cheers
Chris
I'll give a couple of possible reasons;
1. Using Nero for anything other than burning.
2. VBR MP3 or AC3 audio in the source AVI.
Using something like DivxToDVD or the manual way - http://members.dodo.net.au/~jimmalenko/AVI2.DVD.htm - may solve #1. It may even be as simple as extracting the audio to a WAV file - http://members.dodo.net.au/~jimmalenko/ExtractAudio.htm - and then remuxing this into a new AVI with virtualdub (making sure you have Video > Direct Stream Copy selected) and then trying this new AVI in NeroVision.
A GSpot of your source file (See the sticky at the top of this forum - https://www.videohelp.com/forum/viewtopic.php?t=271697 ) will go a long way towards ruling out #2.If in doubt, Google it. -
If you've got room on the blank try changing the audio to LPCM. This sometimes does the trick. Audio sync problems happen with many encoders out there, it's not only a Nero problem as jimmalenko infers.
meGUI Nero AAC encoding error
By ArtOfLosingMFZB in forum DVD RippingReplies: 4Last Post: 16th Aug 2010, 13:46 -
Nero Recode encoding problem
By goodmedo2003 in forum Video ConversionReplies: 4Last Post: 30th Apr 2009, 11:35 -
nero smart encoding
By m baqar in forum Authoring (DVD)Replies: 4Last Post: 27th Mar 2008, 06:13 -
nero 7 out of sync encoding
By sharky007 in forum Authoring (DVD)Replies: 1Last Post: 25th Jul 2007, 05:28 -
Question for Those Who are Familiar with Nero 6 or 7 on Encoding to MPEG-2
By wayney in forum Newbie / General discussionsReplies: 11Last Post: 13th Jun 2007, 20:35
