I've had problems using GraphEdit. I get a "format is not supported" error from media player when I try to open the file.
Here's my graph:
The "Capture.avi" box is a dump filter I downloaded and have used successfully capturing from the hardware encoder. I'm a noobie with GraphEdit, so I'm sure I'm missing something simple.
For those of you who are always asking why someone wants to do something, please just take it for granted that I want to use GraphEdit to capture AVI and leave it at that.
Thanks.
If you replace your dump to CAPTURE.AVI with VIDEO RENDERER, does it play on screen?
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Try to replace the dump filter with a File Writer Filter
(from the Directshow filters).
For slk001 : after an AVI MUx filter, there is no chance even to connect to the Video renderer...Paul Glagla
http://paul.glagla.free.fr/index_en.htm
unlocking Home Theater Samsung HT C-550
By samsungC550 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 17th Jan 2011, 22:07 -
Hardware MPEG-2 Capture Software ATI Theater 550 Pro
By CaZeek in forum Capturing and VCRReplies: 9Last Post: 22nd Nov 2010, 12:57 -
Video goes to snow with ATI Theater 650 pro capturing through s-video
By Des in forum Capturing and VCRReplies: 5Last Post: 26th Aug 2010, 08:37 -
Theater Pro 550
By Jenkjunk in forum Capturing and VCRReplies: 4Last Post: 12th Oct 2009, 22:48 -
Extract Subtitle embled in AVI file,VirtualDubMod n GraphEdit didn't work..
By quang010692 in forum SubtitleReplies: 1Last Post: 5th Oct 2008, 03:44
