    Apr 2005
    Houston, Tx.
    I have been trying to back up the movie Valiant with no luck. I first used DVD Fab to download it onto my hard drive. Then ran shrink on it and it would get to 37% and errored out saying not enough memory. Next I tried using DVD Fab with AnyDVD running to put it on my hard drive. Then used shrink with same results. I tried just using Shrink to back it up with same results as well. Even tried DVD2one V2 but it kept erroring out as well. Any ideas?
    May 2003
    Parsippany, N.J.
    This is how I got it to work. Run DVDfab decrypter, then run Vobblanker, then run dvdshrink. Works fine.
    Sep 2003
    Thanks rkersh409,
    It worked for me!
    justmenow55
  4. I just did this one yesterday:
    rip with anydvd
    with DVDRemake Pro.
    Remove trailers, remove spanish, remove french, fix authoring errors
    run exported result through shrink at 96%
    Plays purty
  5. I had a similar problem using AnyDVD & CloneDVD2 - The first time I extracted it looked fine but when I used Nero to burn the DVD, it failed.
    So I binned the extracted files and extracting again and it burned fine!
    I think the first time AnyDVD sees the DVD, it failed but registered the CSS in it's database, so that by exiting and then restarting, it then saw it the second time and carried on using it's CSS registry.
