Hai to all,
I am having Sony ( DV ) TRV 22 E Handy cam for personal use,,, I want to use for online capturing in Xvid format,,,,,
Can any one suggest which program will be the best result to get Xvid,,, I am using Firewire to get computer connection,,,
I have P4 Intel Pentium / 3.0 Ghz / HD 240 GB / 1 GB Rom / Firewire etc,,,
Thanks in advance,,,
Firewire transfer is just that, a data transfer which will give you a DV avi file on your hard drive. Some software can encode to mpeg during the capture but an on-the-fly encode won't be particularly good quality. AFAIK nothing exists that will encode to Xvid on-the-fly. You'll need to transfer as DV avi and then convert later.
To add to what Richard_G said, the camcorder pass-through converts analog video to a realtime DV stream. The stream can be directed to a file (e.g. WinDV) or it can be directed to another interface (e.g. a second IEEE-1394 port), a display driver or a realtime process (e.g. Mainconcept MPeg2 encoder).
To do what you desire, there needs to be a Xvid encoder with realtime mode and your computer needs to be fast enough to keep the buffers from overflowing and causing dropped frames.
If you first save the live stream to a DV-AVI file, a non-realtime encoder can take its time and reaccess data if buffers overflow.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
delete
By deuce8pro in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 26th Jul 2010, 13:50 -
Sony TRV 138 or TRV 350: do these camcorders have "pass through"?
By tadd5181 in forum Video ConversionReplies: 1Last Post: 24th Apr 2010, 18:38 -
Sony DCR-TRV-20 external mic impedance matching
By Larry Larson in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 21st Sep 2009, 14:54 -
Sony TRV - digital, but record onto Hi8 tapes?
By OM2 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 1st Jun 2009, 12:07 -
Transferring video from Sony DCR TRV 285E to PC ...need dv sample
By ganduman in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 12th Mar 2009, 09:20
