Hi everyone!
I was wondering what you think the best MPEG2 codec is (software)? Not nessasarily only for DVD creation, but also just for compressing, quality, etc. on the computer. Also, is there one that is more widespread/standard than all the others? I have read the info here, but it lists just a few MPEG2 codecs:
https://www.videohelp.com/tools?s=6
I've heard good things about nvidia's purevideo... sadly there were no comments for it @ the above link.
What do ya'll use?
TIA![]()
Buy My Books -
purevideo is a mpeg2 decoder, just for viewing mpeg2 and not making mpeg2.
if you want an mpeg2 encoders see https://www.videohelp.com/tools?s=40#40 -
For encoding mpeg2 to mpeg1
Use avisynth script to feed mpeg2 source to bbmpeg , bbmpeg settings to mpeg1 , and go .
Checkout the forum , you should beable to find info on how this script is put together , it should be also in the avisynth folder , help files , take a look for directshowsource .
Its reasonably fast .
The less process's involved , the better the outcome will be .
Which Mpeg2 compression codec?
By yugurya in forum EditingReplies: 6Last Post: 20th Jan 2012, 01:35 -
proprietary codec used by Sharp for MPEG2
By ghostma in forum Software PlayingReplies: 17Last Post: 16th Nov 2011, 18:11 -
no sound on some movies when playing with ps3 and mpeg2 codec issue
By dhyane in forum Newbie / General discussionsReplies: 1Last Post: 14th Dec 2010, 10:18 -
Probable Codec problem. No audio on MPEG2 muxed files
By Kevlin in forum MacReplies: 14Last Post: 17th Apr 2010, 04:05 -
Virtualdub-MPEG2 - DV-AVI Video Codec For Widescreen
By minko in forum Video ConversionReplies: 16Last Post: 10th Nov 2008, 02:49
