after i burn a vcd and play it in my dvd player, the video is not centered on the screen. its in the top right corner - how do i fix this??
thanx
upps its actually in the top left corner - also im using tmpgenc to encode - PLEASE HELP ME
The 'screen-size' should be 358x240 or 358x288 or else it may look like you described.
flaskmpeg or bbmpeg can change the screen width/height.
I'm not sure TMPGenc can do it.
I had a similar problem. Audio was also skipping. I found out that I was trying to make a 320x240 VCD which doesn't work too well. I wound up stretching it to 352x240 and it was centered (full screen actually) and audio was fixed.
At the time, I was using a Dazzle DV-80(?), a little device that hooks up to USB. Due to the limited bandwidth of USB, it could not capture any better than 320x240. That's why I was forced to stretch it rather than re-capture at 352x240.
Darryl -
but my origninal movie is in 576 * 240 isnt that gonna look aweful once streched?? is there no other way??
That's some kind of widescreen format.
Shrink it, keep the aspect ratio and and set the height 240 and the top and the bottom will be black. like a widescreen movie on a standard tv.
VCD to VCD back-up
By fiiido in forum Authoring (VCD/SVCD)Replies: 4Last Post: 29th May 2011, 12:39 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Philips DVP3960 - picture not centered?
By awp in forum DVD & Blu-ray PlayersReplies: 0Last Post: 24th Jun 2007, 11:18 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
