Hi,
I have a double layer DVD with 4 Movies. I would like to copy only 2 selected movies into a single layer DVD. I copied only their respective ifo files and vob files, but at the menu did not come. I should i do to retify this, if i want to copy selected movies.
Regards,
Kern
Problems are bound to find you sooner or later , as this has been discussed in other messages in the forum .
Your best method to avoid problems :
Create 2 folders , one for each title vob .
Use vobedit to demux the video stream , to the same folder
Same with audio , but you need to know which is the correct stream
You now have vob title , video and audio stream in same folder
Repeat for other title's folder .
When done , delete vob titles .
You may want to convert the audio into ac3 format .
Besweet for that
In any paint program , create you menu background , with 2 menu items , such as name of titles .
You will need to grab , say , the dolby logo , and demux it as well .
Launch dvdauthorgui , add dolby logo video , then audio .
Add another title , from folder one , both video and audio .
Repeat , but add folder two's files .
Goto menu's , create m2v , choose your created menu background .
Hopefully you saved it as a bmp or jpg , and same as required by project , pal is 720x576 .
Now add 2 buttons , and position them where you like .
Link button 1 too title 2
Link button 2 too title 3
Title one will play at start by default .
Author dvd to folder .
Launch pcgedit
Open authored dvd
Go to title 2 , add post command 30 08 00 02 00 C0 00 00
Same for title 3
Save dvd , play test it .
If no audio , install ac3_filters package
Hope that helps , it should help avoid problems with other dvd players .
Rules :
Dvd-r only
Max is 4.3gigs
Burn at 4x for best fixation of burnt media .
Adding existing menu to DVD
By PirateAhoy in forum Authoring (DVD)Replies: 0Last Post: 29th Sep 2011, 13:53 -
Adding Menu to Existing DVD
By HamishT in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2011, 16:23 -
Extracting and editing an existing DVD menu
By sambat in forum Authoring (DVD)Replies: 18Last Post: 21st Mar 2010, 18:23 -
To edit an existing menu, or make a new one ?
By Chainsaw_1 in forum Authoring (DVD)Replies: 5Last Post: 9th Mar 2010, 17:50 -
Create new menu to link to existing menu. Possible?
By Noy2014 in forum Authoring (DVD)Replies: 3Last Post: 14th May 2007, 13:22
