Hi,
I have the above player and have a problem that I cannot get my head around. I purchased the player as it seemed a good budget player with card reader and DIV X playback capability.
The problem I am having is when playing back DVD +/- RW disks. At first - naturally - I put this down to media and have tried numerous of varying quality.
What happens is when I burn a DVD or DIV X files to a DVD RW the player fails to read it (i.e. spins out for up to 10 -15 mins or will give an unknown disk error). If I keep doing a combination of turning the machine off and/or opening the drive tray so that machine re-tries - bang - it reads and play back is perfect. It can take a long long time! Put the same disk in moments later and the errors are back!!
Anyone shed any light why this would be - it is almost like a laser warming up thing!! Very bizarre.
I need to add - write the same files in the same way to any DVDR (no matter how cheap) - perfect - everytime. I generally burn with Nero 7.
Any theories would be much appreciated. I know this player should read DVDRW.
Thanks.
Results 1 to 1 of 1
Vista DVD Playback Problems
By JMMac in forum Software PlayingReplies: 14Last Post: 16th Dec 2010, 13:39 -
DVD Dual Layer playback
By Brfcrule1 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 18th Sep 2010, 10:47 -
Pinnacle 11 - playback issues on DVD - rapid playback problems
By crven in forum Newbie / General discussionsReplies: 5Last Post: 15th Dec 2007, 09:19 -
By thelethal in forum Video ConversionReplies: 7Last Post: 4th Jun 2007, 14:08
