I'm new to burning movies. But this morning I did burn a disc and put it in my DVD player, Sony S300, It played great, had about video tape picture quality and good sound but about 20 minutes into the movie it froze I stopped the disc and restarted it and fast forwarded to the same spot on the disc and it did the same thing only this time it stuttered in other spots in the movie too.
I burned the disc with Nero 5.5 on a Digital Media CD-RW disc with a phillips PCRW1208.
Don't know if I have just been looking in the wrong spots in the website but it seems I have been everywhere and can't find any info on stutters or stalls. If anyone has any info or can point me in the right direction I would really appreciate it.
I have same problem like you. I dont know why but some movies that i encoded do this thing but only at the end of the movie or disc. Here some insturctions might help you
1. Never set the maximum bitrate higher than ~2600kbps (2400kbps for the video + 192kbps for the audio)
2. Use the I-author and Easy CD for authoring (someone kept saying the I-author muxer makes the correct video file)
Don't forget i always do the aboves even so i make wrong disc.
<font size=-1>[ This Message was edited by: gazsi on 2001-12-26 19:12:10 ]</font>
What is the difference between onboard & stand alone video cards ?
By Illusionist in forum ComputerReplies: 18Last Post: 22nd Dec 2009, 20:05 -
Stand-alone Recorder (video blocking signals)
By grom in forum DVD & Blu-ray RecordersReplies: 1Last Post: 19th Dec 2009, 04:19 -
Home DVD Freezes Up in multiple areas of video
By shopforchrist in forum Authoring (DVD)Replies: 1Last Post: 17th Mar 2009, 21:29 -
1080p movie freezes video often
By hugoxalapa in forum Software PlayingReplies: 2Last Post: 8th Sep 2008, 11:53 -
Do you stand your video game console on its side?
By yoda313 in forum PollsReplies: 10Last Post: 2nd Sep 2008, 10:52
