So I've got a CSI Season 5 DVD, and I have a Personal Media Player that plays Xvid and DivX. I know how to rip a DVD and convert to Xvid and DivX. Is there a way to take this TV episode DVD and rip each episode to a separate Xvid or DivX without ripping each episode individually?
Results 1 to 10 of 10
Hi-
You're a little bit unclear. If you're asking if you have to decrypt each episode separately, then the answer is yes. -
I was just wondering if there's a program that will batch decrypt/encode each episode separately.
The way I'd do it is to batch-rip the eps using DVDDecrypter and the commandline mode - see https://www.videohelp.com/forum/viewtopic.php?p=1373527#1373527 for a full explanation.
Then I'd use AutoGK's batch mode to do the encoding.If in doubt, Google it. -
So I've got a CSI Season 5 DVD, and I have a Personal Media Player that plays Xvid and DivXNo DVD can withstand the power of DVDShrink along with AnyDVD!
Not really...I want the episodes to be portable. I'm a college student, and I want episodes on campus. I'm well aware of the quality effects compression has.
Using Nero recode to Nero Digital format is pretty easy to do and does and admirable job producing a MPG-4 I believe. You of course need the full Nero with the correct serial to activate Nero Digital. I have converted a full 2 hour movie to a single 700 meg or for even better wuality a 1400 meg file and it looks nearly as good as the orignal. Specially on a laptop. COnversion time is about 1.5 times the length of the movie on a good machine. You need to first rip using a ripper or simply run AnyDVD in the background so Nero Recode can directly decrypt, rip and convert sll at the same time.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
Would synch mostly occur on DVD to DivX, or XviD to DivX?
By rocky12 in forum Newbie / General discussionsReplies: 3Last Post: 29th Oct 2008, 01:01 -
Weird I don't have XviD or DivX codec installed but I can see Xvid movies
By Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 11:47 -
DivX/Xvid/Whatever to DVD
By FallenAngelII in forum Authoring (DVD)Replies: 4Last Post: 12th Dec 2007, 17:04 -
DVD vs XviD vs DivX ?
By richbell in forum Authoring (DVD)Replies: 6Last Post: 20th Jul 2007, 06:17
