    Oct 2003
    North America
    I have an MP3, and the sound isn't as crisp as it should be. Are there ways to improve the quality (smoother)? In other words, improving the audio after it has been converted to a low bitrate.
    I did some searching on the forums, but I only found how to make audio files louder (normalizing).
    Thanks.
  2. You will need the original audio to make a cleaner MP3.
    You can use filters on your MP3 file but it will just sound worse unless you have non-golden ears.
  3. Member Sifaga's Avatar
    Aug 2003
    Melbourne, Australia
    you cant put back what was taken out
    you could play around with the mp3 in an audio editor, if possible find a better copy of the mp3
    Apr 2002
    Canada
    maybe this can help..http://www.logiccell.com/~mp3trim/
    Oct 2003
    North America
    Oh, I thought there would some sort of filters to do this. (like how you can improve digital pictures that have been compressed too much, using photoshop).
  6. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    Same thing applies with any digital media, photo's, videos, audio, ect.
    Once it's gone, it's gone, you may be able to play around a little in an EQ program, but once it's gone it's gone.
