Am I correct in the fact that you need to connect the i-link cable to PC in order to capture to WinDV instead of USB cable?
iLink is Mac word for firewire, depending what you are capturing from if it has firewire and your computer has it use it, or USB2 .. these are almost the same depends which one your computer can work faster on. We have different speeds of firewire too depending on chip they used. between USB1 and firewire use firewire.
actually, I.Link is the Sony word for firewire, it has nothing to do with Apple.Originally Posted by INFRATOMFriends don't let friends use Windows!
Elisha Cuthbert is so a total schorchcake!! -
Ilink (sony), firewire(mac) or 1394(generic, the name not the cable necessarily) are all the same.
Very fe cams have USB2, you need to use firewire if you want a full qiuality transfer. The USB is for transferring still pics if your cam has that option or low qulaity video for example if you wanted to use as a web cam. -
"iLink" is re:Sony, "Firewire" is re:Apple, IEEE1394 is everybody else.
edit: dangit! coalman, you beat me to the punch!
VCRs, cable box, cable mouse, problems
By judybr in forum Newbie / General discussionsReplies: 0Last Post: 2nd Sep 2010, 14:42 -
PC controlling a cable box (USA time warner cable)
By marcolisi in forum Capturing and VCRReplies: 2Last Post: 4th Aug 2010, 17:24 -
Unable to use HDMI cable with Scientific ATlanta 8300 DVR cable box
By aimee43 in forum DVB / IPTVReplies: 11Last Post: 28th May 2009, 13:21 -
PSU with detachable/modular cable management Vs stable cable(Recommendation
By retroborg in forum ComputerReplies: 3Last Post: 15th Oct 2008, 15:50 -
Such thing as dual link to single link DVI-D cable?
By Mizkreant in forum DVB / IPTVReplies: 1Last Post: 14th Jul 2007, 06:51
