With the Toshiba SD210E, when you read SVCD, audio come 225ms in front of video (many people mentionned this problem in the VCDHelp Compatibility List section with this DVD Player).
I use TMPGEnc to convert AVI to MPEG-2 files.
I'd like to know if this problem is specific with this DVD player, or if TMPGEnc works bad and doesn't produce a SVCD compliant file ?
I've tried to demux (with TMPGenc) and remux (with bbmpeg) audio and video again, but without success.
If you have the same DVD player or another one wich plays fine, any suggestion or explanation are welcome !
Thanks in advance.
I've tried many things, and it doesn't work anymore, always the same sync pb with SVCD.
With VCD no sync pb, so I've tried XVCD with 480x576 or 720x576 resolution (I'd like to keep the SVCD resolution). It doesn't seem to work. Does somebody know XVCD resolutions which work with Toshiba SD210E ?
Any other solution for SVCDC is welcome
Thanks.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
Premiere Audio Sync Problem
By Cedrick Salizar in forum EditingReplies: 1Last Post: 11th Jan 2010, 12:01 -
Audio Sync Problem
By lwea2009 in forum Newbie / General discussionsReplies: 8Last Post: 30th May 2009, 16:19 -
out of sync audio problem
By virendra in forum AudioReplies: 2Last Post: 25th Dec 2007, 07:31 -
New (?) audio sync problem
By oldblues in forum ffmpegX general discussionReplies: 3Last Post: 26th Oct 2007, 11:26
