I like using Studio 9.4 (with updates), but have the apparent infamous AV sync issue. In virtualdub, I have no synch issues, but instead have green color problems in preview and playback.![]()
Can someone give me some pointers in layman's terms? I am getting lost on all the tech.
Things to try to fix sync issues are:
1. Make sure that you capture to a seperate HD, not the one your OS is on. And, not just to a seperate partition.
2. Defrag the HD before you try to capture.
3. Shut down any unnecessary applications that are running. If necessary, try booting up into safe mode to capture.
4. Firewire is the most foolproof capture method, followed by usb2.0. I wouldn't even try other methods.
5. If you are still having sync issues, capture the video by itself, then capture the audio by itself, then join the two in the editing stage.Rob
Easycap Video Grabber Capture card USB 2.0 RCA and S-Video?
By ffxdean in forum Capturing and VCRReplies: 149Last Post: 16th Mar 2011, 01:02 -
Best video capture software? Is AVI better for capture? Is TV screen better
By johnharlin in forum Capturing and VCRReplies: 5Last Post: 21st Feb 2011, 07:17 -
video capture problems - HV20 camcorder is controlled but no video capture
By chebowitz in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 27th Feb 2010, 10:49 -
Problem:Using Video Capture Card for capture or spy another PC.
By gmchn83 in forum Video Streaming DownloadingReplies: 1Last Post: 15th May 2009, 14:56 -
capture advice: USB 2.0 video capture adapter?
By j jasper in forum Capturing and VCRReplies: 10Last Post: 26th Feb 2008, 19:18
