When I insert a blank cd into my Mac G5, the disk drive makes some strange noises, and no blank cd icon appears on the desktop. I can still burn cds through I tunes, but I want to burn some mpegs from my desktop to the blank cd. Any help?
Check you Finder preferences and your system preferences. Be sure you have told the system to show CDs on the desktop.
I have, still nothing. The cd's burn fine in itunes, but they won't just show up on the desktop. Is there a good free burning program for Mac I can use tio burn data, or do I have to still slove this problem?
Have you updated your system software fully? Which version of OSX are you running? How do you have your Prefs set for blank discs?
what type of media is it? Brand? +r, -r?
Do you have toast? If so drop your files in there, click record follow instructions and it will then eject the drive asking you for a cd. put one in, click close tray and it may work
You should find out what your specs are for when you insert a blank cd. my guess is they are just incompatible with your drive [i still cant get some maxell's cd-rs to work!]
Won't recognize disc
By totallylost1 in forum DVD & Blu-ray RecordersReplies: 7Last Post: 9th Jul 2011, 18:57 -
Computer won't recognize all my memory
By ricoman in forum ComputerReplies: 8Last Post: 1st Nov 2010, 16:28 -
PC won't recognize burned files to DVD
By browndav in forum MediaReplies: 6Last Post: 9th Jan 2010, 15:43 -
Sonic won't recognize DVD, computer does ...
By LittleQueenie in forum Newbie / General discussionsReplies: 2Last Post: 17th Oct 2007, 13:06 -
Just installed - won't recognize Real
By fisheye in forum ffmpegX general discussionReplies: 8Last Post: 20th Aug 2007, 02:45
