I've just tested my LG4167B (configured as IDE master) drive's performance against my SONY DVD-ROM DDU1621 (configured as IDE slave) with some common testing softwares:
http://www.geocities.com/come_mon_come_mon
The test results shocked me because it revealed data transfer rate of my new LG drive was even inferior than my old SONY DVD drive bought years ago.
I don't know why this happened (PS: I'd updated the latest firmware to my LG drive).
Could anyone help me![]()
Results 1 to 15 of 15
check to see that your drive is in DMA mode. it sounds like it's stuck in PIO mode.
Control Panel/system/hardware/device manager/<ide-channel>/properties/advanced settings
http://www.cdrlabs.com/phpBB/viewtopic.php?t=7625Originally Posted by come_mon
Most dvd-writers are slower in transferring data to the harddrive than dvd-roms.
But how to explain the test result ? Did the test results properly revealed my drive's performance ?Originally Posted by A_T
This is a very unusual problem. I own an LG GSA 4167B and have had no issues like this (I have had it for a very short time though). There has to be some issue over-looked here. Please give as much info as possible about the hardware setup (motherboard, ide configuration, etc). The 4167B is not the best reader/ripper by no means but those timings you link to are unexplainable. I am no hardware expert but this looks to be more down that alley. Try this link
possibly:
http://club.cdfreaks.com/showthread.php?t=90930
Includes a lot of discussion on various IDE problems and issues. -
Motherboard : Magic-Pro MP-7VIP-DR-LeOriginally Posted by OneSickPup
CPU : Althon, details see http://www.geocities.com/come_mon_come_mon/NeroInfoTool/Info6.JPG
IDE bus configuration http://www.geocities.com/come_mon_come_mon/NeroInfoTool/Info3.JPG
The original IDE position was occupied by Ricoh MP7200A (20x10x40x) -
One more thing, my HD was configured at primary IDE channel master, its a Maxtor D740X-6L (DMA-33) HD.Originally Posted by come_mon
That motherboard has both On-Board 2 x Ultra DMA 33/66/100 IDE Ports and an On-Board Promise IDE RAID Controller. VIA chipsets for North/Southbridge. Your screenshots indicate normal setup on primary and secondary ide channels. I know Promise controllers are considered to be problematic with optical drives but that Raid Controller does not factor in since it appears to be unused. I am at a loss here - way over my head. Maybe some of the guys with more hardware experience will chime in!
Question
- Are you using VIA drivers or Microsoft XP supplied???
That previous link I posted earlier had comments in that thread somewhere that advised against using manufacturer supplied drivers vs. MS supplied ones (I think). As I said - this is beyond my ability to help anymore. Good luck - maybe someone else can help further. You might have better luck posting this kind of issue over at cdfreaks.com in their hardware forum section. -
If you mean VIA Bus Master IDE Controller driver, it's Microsoft XP supplied.Originally Posted by OneSickPup
http://www.geocities.com/come_mon_come_mon/NeroInfoTool/Info5.JPGOriginally Posted by OneSickPup
After case reported to vendor & after long wait, they finally gave me reply. They suggested me to update my XP to SP2. So I did the upgrade. Afterwards, the DVD test results seemed normal (real burning time as well). I will post the result here laterOriginally Posted by OneSickPup
HL-DT-ST DVDRAM GSA-T20N read speed too slow!!
By tmangia in forum DVD & Blu-ray WritersReplies: 10Last Post: 17th Aug 2010, 06:44 -
God shoes
By deadrats in forum Off topicReplies: 3Last Post: 8th Dec 2009, 13:34 -
The Hand of God
By deadrats in forum Off topicReplies: 2Last Post: 26th Apr 2009, 10:32 -
Slow Read Rate
By mr240 in forum Newbie / General discussionsReplies: 5Last Post: 19th Jan 2008, 18:41
