  1. SECOND ANNUAL MSU MPEG-4 AVC/ H.264 CODECS COMPARISON RELEASED!
    (Formal comparison of new standard codecs)
    Main features:
    * 7 H.264 codecs was compared with last DivX.
    * All H.264 codecs and there settings was received from codec developers directly for test.
    * 2 presets, received from codec developers, was measured:
    "Max PSNR" - maximum quality (slow)
    "Max speed" - maximum speed
    Speed and quality was measured in both presets.
    * We measure PSNR, SSIM, VQM, Blurring, Blocking, Bitrate handling, time.
    * Clean calculation time was more than 20 days on P4-2400.
    * Measurement program was published for sure (and for free ).
    Was tested:
    # DivX 6.0 (NOT H.264 video codec, tested as reference MPEG-4 ASP codec)
    # ArcSoft H.264
    # Ateme H.264
    # ATI H.264
    # Elecard H.264
    # Fraunhofer IIS H.264
    # VSS H.264
    # x264
    Video sequences that were used in this comparison
    # “foreman” (standard sequence)
    # “susi” (standard sequence)
    # “BBC” (standard sequence)
    # “battle” (part from "Terminator-2" movie)
    # “simpsons” (part from "The Simpsons" movie)
    # “Matrix” (part from "The Matrix" movie)
    # “Concert” (part from HDTV movie)
    Comparison page: http://compression.ru/video/codec_comparison/mpeg-4_avc_h264_2005_en.html
    PDF (3.5Mb): http://compression.ru/video/codec_comparison/pdf/msu_mpeg_4_avc_h264_codec_comparison_2005_eng.pdf
    PDF in ZIP (2.6Mb): http://compression.ru/video/codec_comparison/zip/msu_mpeg_4_avc_h264_codec_comparison_2005_eng.zip
    In plans:
    * Measurement of H.264 codecs with formal visual tests.
    * Usage of new metrics.
    * Bigger number of codecs (we already has requisition for new codecs)
    Enjoy!
    With regards
    Dmitriy Vatolin
    http://www.compression.ru/video/ (News: new metrics and WMP vs JPEG-2000 comparison)
    Senior editor of Compression-links.info
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Thanks for those links. Very valuable.
    http://www.kiva.org/about
