I am using HDTV2DVD. When I try to drag an mpg to my assets, the cursor changes to the plus sign as if it's going to copy it but nothing happens. How do I get my mpg in there to edit?
It will only accept MPEG2 Transport Streams. In addition to that they must have a .tp or .ts extension. So if you have a mpeg (which is a transport stream, not a program stream) make sure it has the aforementioned extension - rename if not.
(Mp4, AACv2, MKV, Webm, Theora) Drag Drop Convert GUI Update v 1.2.0.0
By richter03 in forum Video ConversionReplies: 11Last Post: 21st Apr 2013, 06:35 -
Drag and Drop Assets
By scoooter1 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 7th May 2011, 05:37 -
Drag n Drop Problem
By Jim255 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 29th Mar 2011, 04:26 -
HDTV2DVD will not let me drag and drop .ts file into "assests"
By Dollybono in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 4th Mar 2009, 06:38 -
Author tool that allows for drag-n-drop template authoring?
By jlietz in forum Authoring (DVD)Replies: 2Last Post: 16th May 2007, 13:54
