Hi
I got 2 avi files that Im trying to merge with a joiner but they have different sampling rates, which says may cause problems. Avi 1 has a 16914.00000 rate and avi 2 has a 16900.00000.
What tool can I use to change the sampling rate and what rate are both my avi's supposed to be, to be correct and avoid error's???
Cheers
monkeyballz,
I don't know of too many tools that will merge/join two disparate audio/video streams. In audio and video, 'close' usually isn't enough.
I'd recommend reenconding to the same rates and then merge/join. Probably could do both steps (reencode, join) at the same time. Virtualdub should be able to help you if you stay in .avi territory.Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/ -
You can only correctly cut/join avi's from the same encoding or capture session so that metadata from the final file's header (encoder type, pixel resolution, VBR settings and other important things) allow to properly playback any part of the final video. Some join utilities won't show error messages (VirtualDub does if something is wrong) but you can find problems in the end.
Audio Sampling Rate Info Wrong - DV-AVI Capture
By newtotheworld in forum Capturing and VCRReplies: 3Last Post: 21st Nov 2011, 23:18 -
Program like XenonMKV but with sampling rate conversion?
By shanghei in forum Video ConversionReplies: 1Last Post: 11th Nov 2011, 09:20 -
Understanding Video sampling rate
By Movie-Maker in forum Newbie / General discussionsReplies: 2Last Post: 25th Aug 2008, 18:07 -
Transcoding Video - Bitrate, Sampling Rate etc Limits?
By Leo48 in forum Newbie / General discussionsReplies: 18Last Post: 22nd May 2008, 09:38 -
Issues with sampling/audio sampling/data rates and VdubMod
By Suprman37 in forum Video ConversionReplies: 4Last Post: 22nd Feb 2008, 02:09
