I currently have a Pio 108 and Litew-On 1633 and am looking to replace the Lite-On unit as it has alot of problems reading some discs. I want to use the Pio 108 for playback and the new unit (either the 100 or 610) for recording. I've read a number of issues with the 110 and was wondering how good/bad the 610 is in comparison. Any suggestions?
Pioneer DVD writers are usually always great quality. Even lesser quality brands like Lite-On and NEC are rock solid. Should not have much issues with either pioneer burner,but it could'nt hurt to look at the reviews to see which is slightly better.
I recommend buying from newegg.com,its a great place with good prices and its EASY to return stuff your not satisfied with.User reviews are usually good on stuff as well.
Caopus ADVC 110 issue
By codeman in forum Capturing and VCRReplies: 2Last Post: 11th Dec 2011, 15:56 -
Macrovision and Canopus ADVC 110
By nikgelfi in forum Capturing and VCRReplies: 2Last Post: 13th Apr 2011, 17:09 -
Canopus ADVC 110 Possible problem?
By Drexter in forum Capturing and VCRReplies: 4Last Post: 20th Feb 2010, 22:10 -
ADVC-110 and Vista
By shkinnybob in forum Capturing and VCRReplies: 3Last Post: 3rd Aug 2007, 17:23 -
Philips DVDR 610 Problems
By Rachel85 in forum DVD & Blu-ray RecordersReplies: 10Last Post: 24th Jul 2007, 09:36
