I'm searching for good DVD Lab Pro tutorial link on the net, especcially I want to learn how to produce DVD that automatically start when insert disc into DVD player, roll short video clip (advertising clip or some warning for example) and then DVD Menu appears (first play option).
Regards.
QUALITY HAS A NAME
Have you read the manual that comes with DLP ? If you look up first play it will tell you how it works.
Mediachance.com has the best collection of tutorials for DLP, however for what you have asked, a tutorial is overkill
Connections window. Drag a connection from the first play icon to your short clip, then a connection from your short clip to your first menu. It is that simple. Most of the tutorials expect you can get at least that far from the manual alone.Read my blog here.
Originally Posted by MI6
That's like the 2nd Default Empty Project when you open DVD-lab PRO, except you have to draw the connection line. If it was a rattlesnake you'd already be dead :P
Originally Posted by guns1inger
help with DVD Lab Pro
By medo_256 in forum Newbie / General discussionsReplies: 1Last Post: 22nd May 2010, 21:02 -
Vegas pro 9 professional tutorials
By freestyler9 in forum EditingReplies: 1Last Post: 30th Jan 2010, 07:51 -
Help with DVD-lab PRO.
By angles in forum Authoring (DVD)Replies: 2Last Post: 3rd Jan 2010, 17:19 -
Help with DVD Lab Pro
By blacksheepdownunder in forum Authoring (DVD)Replies: 12Last Post: 31st Dec 2009, 23:01 -
DVD Lab Pro 2 help
By jonghyunchung in forum SubtitleReplies: 1Last Post: 17th Jan 2008, 07:53
