Hi: I recently purchased a new PC. The graphics card is integrated ATI Radeon 200. I am planning to buy a HDTV tuner for this and want to be able to connect it to my HDTV which has a HDMI interface. How do I connect my PC to the HDTV?
1. Am I better off to have two cards HDTV tuner and a Video output card such as a HDMI PCI card? If so are there any HDMI PCI cards?
2. Are there any PCI type HDTV tuners that will output it to a HDMI output built on on the board without taxing the PC CPU?
3. Are there any PCI type HDTV tuners that will output it to a S-Video or Component output built on on the board without taxing the PC CPU?
Any other suggestions.
Ravi
First check on DVI cables, they are very expensive and short. for 2.5 meter (~6ft) $150 for Monster and $100 for regular brand. It may not worth connecting computer to HiDef TV.
100 bucks! man i've got about 5 dvi cables sitting in my room right now!
I know some of the ati radeon cards have the capability to use a dvi to component adapter to connect to your tv. you might want to look into that as well. -
First, what is a Radeon 200 card? OEM?
Is your mobo connection AGP/PCI or PCI Express?
Best to wait on new output cards if just for HDTV. The cards are evolving and are not yet ready for MPeg4 (H.264, VC-1, DivX) or are way too expensive intended for developers.
AGP cards 9550 - 9800 can be hooked up with analog component at 480p, 540p, 720p, or 1080i and are cheap and good enough until the HD DVD becomes available. With many of these cards DVI connection to HDMI is possible depending on the TV.
What model TV do you have?Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
edDV: I have a Toshiba 61" HDTV without the tuner. The computer is not just for HDTV. I use it for other purposes too. But I want to use it to record OTA HDTV signal and be able to play it on my TV.
I think the Video card is part of the motherboard. (ATI Radeon® Xpress 200 (PCI-Express®) 128MB DDR shared video memory).
Ravi
Originally Posted by edDV -
Need two+ more details.
1. TV model number, ... or you can tell me display technology, input connections , native resolution, PC resolution support resolutions?
2. Computer motherboard graphics support: PCI? AGP? PCI Express?
3. Might as well tell me the processor and memory.
It is looking like you are limited to less than 640x480 low resolution over S-Video to the TV. You can watch HDTV (up to approx 1280x720) on your computer monitor if you get a HD tuner card.Recommends: Kiva.org - Loans that change lives.
edDV:
1. Toshiba DLP 62" (62HM84: 62" Diagonal HD Monitor DLP™ Projection TV with HDMI). It has S-Video (2), Component(2) inputs.
2. AMD Athlon™ 64 3400+ Processor. I think it has a motherboard graphics support: PCI express (ATI Radeon® Xpress 200 (PCI-Express®) 128MB DDR shared video memory). Definitely not PCI.
3. 1G RAM and 200G HDD.
Ravi
Get one of the ATI Xnnn (3 digit) cards for basic HD output connnection (1080i scaled in the TV to720p) or 720p direct.
The more expensive Xnnnn (4 digit) cards have the Avivo MPeg4 provisions and the Crossfire dual processing paths. Don't expect these to work well yet. We know how long it takes for ATI to debug software. Wait for the $350-550 prices to come down.
http://www.ati.com/products/RadeonX1800/index.html
At the low end, you may be able to get analog component 1080i or 720p from the Xpress200 chips. That would depend on the motherboard manufacturer. You need to ask them.
http://www.ati.com/products/radeonxpress200Intel/specs.htmlRecommends: Kiva.org - Loans that change lives.
Good HDMI or Component Capture Card for Game Consoles?
By jargus in forum Capturing and VCRReplies: 18Last Post: 26th Jan 2011, 10:37 -
Connect VGA/DVI/HDMI source to Component HDTV
By jstewar9 in forum Media Center PC / MediaCentersReplies: 0Last Post: 13th Jan 2010, 15:11 -
Connecting XBOX 360 with 720p Plasma HDTV: So HDMI or Component Av Cable??
By jajabinks92 in forum DVB / IPTVReplies: 2Last Post: 29th Nov 2008, 08:16 -
Need al little help getting my new ati hdtv pci card to sense HDTV channels
By MidnightMike in forum ComputerReplies: 8Last Post: 23rd Jul 2008, 02:12 -
My DLP HDTV accepts 1080i through component input, vid quality = HDMI?
By Denvers Dawgs in forum Off topicReplies: 4Last Post: 9th May 2007, 13:16
