Hi
I converted a VOB file to to a movie clip using VOB2MPG. When I tried to edit the MPEG file using Windows Movie Maker, I recieved the following error message.
C:\Documents and Settings\Owner\Desktop\wedding\New Folder\VTS_01.mpg could not be imported. An interface has too many methods to fire events from
Should I be using this program to rip the file from my DVD or should I be using something else. I tried rejig but it keeps on coming up as a file to be used by my DVD player.
If you are looking for an APP to rip a dvd, then use DVDFab Decrypter
Windows Movie Maker and MPEG-2 seem to be very hit or miss - it's never worked for me. I convert to DV-AVI then import that into WMM.
If in doubt, Google it. -
Jim
Is there a program that can be used to convert the file to DV-AVI? Do you have any suggestion?
Thanks -
AutoGK, Dr. DivX, or Virtualdub will do the jobOriginally Posted by revolve99
If it were me, I would go with AutoGK; Its quick to set up, easy to use, and produces a great xvid
MPEG won't import after converting using VOB2MPG
By olweiser in forum Video ConversionReplies: 3Last Post: 20th Aug 2010, 12:44 -
Unable to install VOB2MPG or VOB2MPG PRO
By tooc in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 28th Mar 2010, 00:53 -
Want to keep chapter markers with Vob2MPG in single mpeg
By Pontyac in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 8th Jan 2010, 12:14 -
VOB2MPG (converted MPG file has no audio!)
By sonicdeth in forum SVCD2DVD & VOB2MPGReplies: 28Last Post: 5th Jan 2010, 19:23 -
Edit, add, extract WAVE and edit file tags with new Machete 3.5
By MacheteSoft in forum Latest Video NewsReplies: 0Last Post: 23rd Dec 2009, 10:05
