I went to the apple website and found a list of third-party applications that you can put on your iPod. They have a range of programs to download from, mostly being cool little things you can do to make your iPod yours.
I downloaded, being a college student (and thinking it would be a coversation) , ones having to do with having a list of how to make mixed drinks. Anyways, they are .dmg files and I have no idea how to put them on my iPod and make them work.
Anyone try any of these or have instructions how to work them?
FYI: I have the latest 30gb Video iPod, and the latest iTunes and came up with nothing finding a solution
DMG is the compressed file format Mac OS X uses. You might be able to open it with Winzip or Winrar, or google for a utility to open it.
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
I wonder if you even should extract them before putting them on the pod. If that disk image was created in HFS+ it may give you a heap of trouble. There must have been instructions available to all users where you downloaded it from. If not go over to www.ilounge.com and see if you can stir up an answer there.
FB-DIMM are the real cause of global warming -
here's the link http://www.apple.com/downloads/macosx/ipod_itunes/
Now that I'm reading it though, I think I'm SOL anyways. Could be wrong, but I think they are only for MAC systems. Am I wrong?
Why don't you need special "accurate" ripping programs to copy DVDs?
By sldvd in forum Newbie / General discussionsReplies: 6Last Post: 15th Aug 2010, 05:30 -
Installing programs to directory other than "default".
By Xylob the Destroyer in forum ComputerReplies: 5Last Post: 18th Aug 2008, 17:01 -
Seeking "One-Type-Fits-All" format to display on iPod, PSP and Bl
By GrayStrickland in forum Portable VideoReplies: 0Last Post: 25th Mar 2008, 09:12 -
Aspire Digital AD-8091 DVD Recorder "skips" when records programs
By ray2000 in forum DVD & Blu-ray RecordersReplies: 16Last Post: 14th Feb 2008, 08:57 -
Why to make "back-up's" of DVD's or TV programs?
By JimboS in forum Newbie / General discussionsReplies: 11Last Post: 11th Jun 2007, 05:39
