Hope this is the right forum to post this.....
Help!![]()
Here is my situation:
I have an NEC DVD-RW ND3540A (which I put in an external USB 2.0
enclosure to be an external DVD burner) and I backed up a movie with DVD dual layer disc from Memorex (2.4x). I used the latest version of
AnyDVD, 1CLickDVDCopy and CopyToDVD to burn the DL disc.
I can play the burned DL disc in the NEC burner but have problem when I put the newly burned DL disc in both my computer (Toshitba
laptop) and a standalone DVD player. Both the computer and the standalone player are unable to even load the DL disc. It kept spinning and reving up and down but can't seem to load the header (my guess).
I checked the burned DL disc and the original movie disc and both
indicated DVD-ROM (type I), according to AnyDVD. However, the
original movie (also a DL) can player in the computer and the standalone player!? I also tried it with a DVD+R (with compression) on the same movie and the resultant DVD+R disc played both on the computer and the standalone. This seems very strange!
Later on, I used DVDShrink 3.2 with Burn Settings for high compatibility
DVD+R/RW (Burn at least 30 mm). The same problem occurs!!
What do I need to do so that I can burn a DVD DL disc such that it can play in my NEC, computer, and standalone DVD player.
BTW, my computer is a Toshitba Laptop.
Thanks in Advance,
FMachine
PS: I have used Intervideo software to seem it makes a difference and the same problem occurred......![]()
Results 1 to 15 of 15
I would use DVD Decrypter to rip the disk in ISO mode (Mode->ISO Read), then use it gain to write to the DL disk (Mode->ISO Write). If you must (for current protection) run anyDVD in the background.
If you are simply copying a DVD to a DL disk, with no reauthoring going on, DVD Decrypter still seems to be one of the best ways.Read my blog here.
Use VERBATIM DUAL LAYER media instead of MEMOREX. As gunslinger mentioned use DECRYPTER to read and write when burning DL media.
I agree with the Verbatim comment. I had no problem burning Memorex and Ritek discs but neither will play in my Sony standalone DVD player or my computer DVD drive (the one that they were burned on) (they load but freeze as soon as they hit the second layer). With Verbatim I have had no problem whatsoever.
I always burn my +DL with Nero and the book type set to DVD-ROM. They can all play on any DVD players. You may have a try.
Just a dumb question. Does your other system have a dual layer supported drive? Does your standalone support dual layer discs?
ROF,
I think the standalone and the dvd rom in my
laptop can play movies which are dual layer.
So I don't see why they don't support DL.....
So this is a common problem with Memorex DL
discs? Or could it be hardware related to my
NEC burner? -
Possibly both, but there are some who have gotten the Memorex DL discs to work, and Memorex is a large company (they wouldn't sell stuff that just plain doesn't work, would they!!??Originally Posted by fmachine1972
), so it is more likely that your burner doesn't like the discs for some reason. Only hope I think is for a firmware update to your NEC that works w/the Memorex (Ritek, I believe) DVD+R DL discs.
I bought a 3-pack of the Memorex DLs, and got 3 coasters out of the deal. Never again, at least not until I see "improved support for Ritek DVD+R DL discs" in the Pioneer firmware release notes (I have a Pio DVR-109). -
Thanks for the advices regarding quality of DVD DL.
I bought some Verbatim DL and one of the standalone
can play the burned Verbatim but had some difficulty
reading the second layer....
So this proves that Memorex DL are "junk" in some sense.
BTW, I tried to backup the movie using NERO and
specified the burned DVD to be in DVD+R but it
still is in DVD-ROM format? Is this related to my NEC
ND3540A not having the updated firmware version?
And how do I update firmware? Thank you. -
I am having a similar problem to fmachine. I have the NEC ND-6650-A, and i just burned a DVD+R DL. When i tried to play the DVD on my laptop, desktop, and dvd player it would spin, but the screen stayed blank.
The Media i used was Fujifilm DVD+R DL, are these discs shit as well, and can you guys answer the firmware update question for me 2? -
oh ya, any ideas of where i could get DVD Decrypter now that it is not freeware because it was bought out/illegal?
I just used Nero CD-DVD Speed to check out the shitty disc i just burned, and apparently it is Ritek as well. I also says Disc Type: DVD+R DL
Book Type: DVD-ROM
is this the same shit as wut happened to fmachine1972 -
I have a 3540a,and my first burns were with memorex.They played on me dvd player,but would not play on a friends computer or dvd player.They are riteks and not very compatable.I have since updated my burner software to 103 bt from http://liggydee.cdfreaks.com/page/3540/
and updated the record now deluxe engine from http://www.orlogix.com/support.php
every dual layer verbatim or fujifilm disc i make plays in every dvd player with no layer switch problem.bmiller,ont.canada
DVD Dual Layer playback
By Brfcrule1 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 18th Sep 2010, 11:47 -
Dual layer disc error (2nd layer not burning properly - AVCHD)
By hhhgamewmx7 in forum Authoring (DVD)Replies: 7Last Post: 24th Aug 2008, 10:00 -
Problems with Dual Layer disk burning.
By qaa in forum Newbie / General discussionsReplies: 19Last Post: 21st Apr 2008, 02:47 -
Dual Layer problems
By cloudsdestiny in forum DVD RippingReplies: 4Last Post: 30th Dec 2007, 02:23 -
dual layer DVD-R in single layer burner?
By snafubaby in forum MediaReplies: 5Last Post: 4th Oct 2007, 14:39
