what tool is the best for converting wav files to surround? Also is there any tool that can take in six separate wav files and then use that to create a surround sound file (ac3 or dts)? I am not sure if the gui4ffmpeg can do this. I read things on BeSweet and it seems a little complicated. Please help I'm new to the audio conversion. thanks
You can use one of the guis for besweet so you don't have to worry about the commandline interface. BeLight is on GUI to look at. gui4ffmpeg or ffmpeggui are about the only other free choices.
Surcode produce software for creating DTS or AC3 audio from seperate mono tracks, but it isn't cheap. Vegas can also fo it with the AC3 plugin.
Most other software will only produce 2 channel AC3.Read my blog here.
Anyway to convert MKV DTS to AC3 5.1 surround sound?
By Patsfan37 in forum AudioReplies: 24Last Post: 7th Jul 2016, 06:17 -
Our motherboards with DTS virtual surround sound my only choice?
By MarcMiller in forum Newbie / General discussionsReplies: 1Last Post: 3rd Nov 2011, 10:30 -
3d video with dts sound how to convert to ac3 sound
By fredddiemercury in forum Video ConversionReplies: 4Last Post: 2nd Nov 2011, 14:54 -
Burn a AVI file w/ AC3 to DVD and get the surround on it?
By WBFAir in forum DVD RippingReplies: 4Last Post: 31st Oct 2011, 14:07 -
Make an xvid/avi from DVD but keep original ac3 surround sound?
By coolchris in forum Newbie / General discussionsReplies: 2Last Post: 26th Jan 2008, 07:35
