I was readign through the manual to see if there was an answer, but i couldnt find anyhting.
what Im trying to do is have a video that loops after it completes for the duration that a song is played. i thought of just setting up a menu witha motion background of the video i want and then adding the song to the audio line of the menu, but how to i set it to loop just the video and not to loop the audio until it has completed since the song is like 3 minutes long and the video clip only lasts for 15 or 20 seconds. so i want the video to loop continuously while the audio does the same but only after it is done.
when i just tried it without changign any settings, when i played it, the whole menu just loops for the length of the video so the audio resets itself every 15 seconds.
the other method i thought might work would be to create an audio only movie as per the insctructions in the manual, and then double clicked on it to open the menu-like area to add a still. instead of a still, I plugged in the video. of course when i authored it and tried to play that movie track, it wouldnt open the link at all and when i tried to play it on a pc, it would just freeze and crash any video player i tried.
what do i need to do to get this to work? thanks
actually, i do use mpeg video wizard for some cutting, do you know if that program allows for that sort of thing? i couldnt find any menu options about it
well i was able to use mpeg video wizard to create the videos i wanted, but after all the work, i cant get them to play in the dvd.
in mpeg video wizard i export the video and audio tracks of the created file seperately since dvd-lab would demultiplex them anyway. then i take those and import them to dvd-lab and they would not give me any errors. so i added each video to a movie section and then point a menu line to each video. the compile goes fine without any errors and then i burn the disc.
when i try to play either of the three videos i created, it just freezes up and refuses to start the video. i tried it in my pc and in a stand alone dvd player, both will not start the videos. what could be holding this back?
Basic Issue - want to make video loop using DVD Studio Pro
By Donny Rowles in forum Authoring (DVD)Replies: 2Last Post: 19th Sep 2011, 14:56 -
DVD Lab Pro 2's Render Menu Motion - Intro and Loop Questions?
By xhonzi in forum Authoring (DVD)Replies: 3Last Post: 21st Sep 2009, 18:52 -
DVD Lab Pro Transitions question
By phatk9999 in forum Newbie / General discussionsReplies: 3Last Post: 19th May 2008, 04:06 -
Question for those that use DVD-Lab Pro
By PharmBoy in forum Authoring (DVD)Replies: 2Last Post: 16th Apr 2008, 23:26 -
loop entire video in dvd lab pro?
By sarcastik in forum Newbie / General discussionsReplies: 1Last Post: 18th Nov 2007, 20:04
