  1. hi my kvcd template for tmpgenc plus 2.5 says no audio will be created, can anyone tell me why that is? or is there audio going to be made it just says there isnt.? and what is the best burning speeds for kvcd? a lot of kvcds chop up near the end while watching them, that normal?
    thx thx thx
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    http://kvcd.net might be a better place for in-depth kvcd questions and answers.
    I believe that that's just the way the templates are by default, but it is quite easy to load the unlock template then select MP2 audio then re-save the template so it is included "by default".
    If in doubt, Google it.
  3. 1. Because TMPG audio encoding is bad.
    2. No, you must make it separately.
    3. 8x
    4. No, this is not normal.
    5. You are welcome
  4. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    6. kvcd is a waste of time?
