For some reason when I put 2 avi files together it takes a long time to merge them into 1 titleset, it takes like 15 minutes , but if i use virtual dub to do it , it takes about 2 minutes. When svcd2dvd is finished merging them, it then spends about 30 minutes or more correcting pts values, for some reason it goes past 100% and goes past 2000%! I thought, wtf how can it possibly complete something 2000% which is 20 times over? Is there a way to fix this or something?
Sounds like something is wrong... can you post your log file?
I think this is the right one.
************************ SYSTEM INFORMATION ************************
***************************** SVCD2DVD *****************************
Title: 2.0
Version: 2.0.2034.36335
Executable: D:\SVCD2DVD.exe
Executable size: 2.42 MB
Executable size in bytes: 2539603
Executable CreationTime: 27/07/2005 20:12:04
Executable LastWriteTime: 21/10/2005 20:02:36
Executable LastAccessTime: 12/12/2005 04:08:14
************************* Operating System *************************
Operating System: Microsoft Windows XP Professional
Service Pack: Service Pack 2
Version : 5.1.2600
Windows Directory : C:\WINDOWS
OSLanguage: 1033
CodeSet: 1252
CountryCode: 44
Local: 0809
Total Physical Memory: 0.99 GB
Free Physical Memory: 588 MB
Total Virtual Memory: 1.99 GB
Free Virtual Memory: 1.96 GB
***************************** Computer *****************************
Computer Manufacturer Name: American Megatrends Inc.
Computer Model: Uknown
System Type: X86-based PC
Computer Name: PC2
DomainRole: x2c3419cdc9b8e007
Number Of Processors: 1
User Name: PC2\Ash
***************************** Processor ****************************
Manufacturer: AuthenticAMD
Processor: AMD Athlon(tm) XP 2600+
Description: x86 Family 6 Model 10 Stepping 0
CPU Speed: 1.916GHz
CPU FSB: 166MHz
L2 Cache Size: 512 bytes
***************************** Time Zone ****************************
Time Zone: (GMT) Greenwich Mean Time : Dublin, Edinburgh, Lisbon, London
****************************** VIDEO *******************************
Name: ALL-IN-WONDER 9800 SERIES
Processor: RADEON 9800 AGP (0x4E48)
Mode: 1152 x 864 x 4294967296 colors
Video Ram: 128 MB
Status: OK
Name: ALL-IN-WONDER 9800 SERIES - Secondary
Mode:
Video Ram: 128 MB
Status: OK
****************************** Drives *******************************
DeviceID: C:
FileSystem: NTFS
FreeSpace: 66.4 MB
DeviceID: D:
FileSystem: NTFS
FreeSpace: 15.1 GB
DeviceID: E:
FileSystem: NTFS
FreeSpace: 8.57 GB
********************* END OF SYSTEM INFORMATION ********************
************************* ProjectMetaData **************************
<SVCD2DVD DateTime="12/12/2005 04:09:11"><AssetSet><Asset ID="66ac5465-0497-4acf-befc-73f935cf7fdf" Path="D:\" Filename="****" /><Asset ID="9f763bba-fde0-4e99-b132-9f26f4237cb2" Path="D:\" Filename="*******" /></AssetSet><DVDStructure><TitleSet Name="New Movie" PostCmd="" MenuButtonType="0"><MenuButton X1="0" Y1="0" X2="262" Y2="49" FontFamily="Tahoma" FontSize="28" FontStyle="3">Menu Button</MenuButton><Title Name="******" AssetID="66ac5465-0497-4acf-befc-73f935cf7fdf" MplexOffset="0" /><Title Name="******" AssetID="9f763bba-fde0-4e99-b132-9f26f4237cb2" MplexOffset="0" /></TitleSet><DVDMenu TVStandard="PAL" Normal="-1" Highlight="-65536" Active="-16711681" ShowPlayAllButton="False" DSOffsetWidth="1" DSOffsetHeight="1" DSColor="0" DSOnOff="True" BackgroundImagePath="D:\default.jpg" AudioPath="D:\silence48.mp2" /></DVDStructure><Settings><General InitialAssetFolder="" InitialDVDFolder="" InitialProjectFolder="" /><Menu AudioEncoding="Silence_mpa" DefaultCustomAudioPath="" DefaultCustomImagePath="" TVStandard="PAL" FontFamily="Tahoma" FontSize="28" FontStyle="3" PlayAllText="Play All" /><Process AudioEncoding="skip" Chapters="Every 0 mins (none)" SkipMPA48="False" SkipAC3="True" PanSan="False" MergeTitles="True" UsePulldown="True" PAL2NTSC="False" AVI2PASS="False" AVI2HALFD1="FS" NoBframes_FullME="False" /><Program BINExtraction="vcdxrip" VCDGearFIX="False" FastAudioEncode="True" /><Burning BurningMethod="NONE" DVDDrive="SONY DVD-ROM DDU1613 " NeroWriteSpeed="Max" Eject="True" HighDVDCompat="True" VerifyDVD="False" DVDDecrypterPath="" DVDDErase="True" DVDDClose="False" DVDDDontBurn="False" /></Settings></SVCD2DVD>
Processing assets for DVD creation
=================== AV Details ===================
file=D:\******
Num_Frames=87816
DurationInSecs=3512
Duration=00:58:32.6
VideoCodec=mpeg4
Width=640
Height=352
Standard=PAL
BitRate=1671
AudioStreamCount=1
Audio1SampleRate=48000
Audio1Codec=mp3
Audio1BitRate=128
Audio2SampleRate=-1
Audio2Codec=NULL
Audio2BitRate=-1
AVI2MPG: 5160kbs Full-D1
Looking for AVI PAR...
Pass 1/1: Processing ********i
04:09:12: ffmpeg version 0.4.9-pre1, build 4757, Copyright (c) 2000-2004 Fabrice Bellard
04:09:12: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --enable-vhook --disable-debug
04:09:12: built on Jul 27 2005 15:48:58, gcc: 3.2.3 (mingw special 20030504-1)
04:09:12: Input #0, avi, from '********':
04:09:12: Duration: 00:58:32.6, start: 0.000000, bitrate: 1671 kb/s
04:09:12: Stream #0.0: Video: mpeg4, yuv420p, 640x352, 25.00 fps
04:09:12: Stream #0.1: Audio: mp3, 48000 Hz, stereo, 128 kb/s
04:09:12: Output #0, dvd, to 'D:\*********:
04:09:12: Stream #0.0: Video: mpeg2video (hq), yuv420p, 720x576, 25.00 fps, q=1-31, 5160 kb/s
04:09:12: Stream #0.1: Audio: ac3, 48000 Hz, stereo, 448 kb/s
04:09:12: Stream mapping:
04:09:12: Stream #0.0 -> #0.0
04:09:12: Stream #0.1 -> #0.1
05:19:38: video:2144826kB audio:186219kB global headers:0kB muxing overhead 1.964293%
05:19:38: AVI2MPG: done.
file=D:\*******
Num_Frames=87967
DurationInSecs=3518
Duration=00:58:38.6
VideoCodec=mpeg4
Width=640
Height=352
Standard=PAL
BitRate=1652
AudioStreamCount=1
Audio1Codec=mp3
Audio1BitRate=128
Audio2SampleRate=-1
Audio2Codec=NULL
Audio2BitRate=-1
Pass 1/1: *********
05:19:43: ffmpeg version 0.4.9-pre1, build 4757, Copyright (c) 2000-2004 Fabrice Bellard
05:19:43: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --enable-vhook --disable-debug
05:19:43: built on Jul 27 2005 15:48:58, gcc: 3.2.3 (mingw special 20030504-1)
05:19:43: Input #0, avi, from 'D:\*******':
05:19:43: Duration: 00:58:38.6, start: 0.000000, bitrate: 1652 kb/s
05:19:43: Stream #0.0: Video: mpeg4, yuv420p, 640x352, 25.00 fps
05:19:43: Stream #0.1: Audio: mp3, 48000 Hz, stereo, 128 kb/s
05:19:43: Output #0, dvd, to 'D:\*******':
05:19:43: Stream #0.0: Video: mpeg2video (hq), yuv420p, 720x576, 25.00 fps, q=1-31, 5160 kb/s
05:19:43: Stream #0.1: Audio: ac3, 48000 Hz, stereo, 448 kb/s
05:19:43: Stream mapping:
05:19:43: Stream #0.0 -> #0.0
05:19:43: Stream #0.1 -> #0.1
05:50:51: [mpeg2video @ 0070A780]rc buffer underflow
05:50:51: [dvd @ 00410EB4]buffer underflow
06:21:23: [dvd @ 00410EB4]buffer underflow
06:28:27: video:2185441kB audio:191751kB global headers:0kB muxing overhead 1.993120%
06:28:27: AVI2MPG: done.
Merging TitleSet #1
Merging:**********
Merging: **********
Correcting PTS values: ***********
06:37:49: ffmpeg version 0.4.9-pre1, build 4757, Copyright (c) 2000-2004 Fabrice Bellard
06:37:49: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --enable-vhook --disable-debug
06:37:49: built on Jul 27 2005 15:48:58, gcc: 3.2.3 (mingw special 20030504-1)
06:37:49: Input #0, mpeg, from 'D:\*********':
06:37:49: Duration: 00:58:24.2, start: 0.500000, bitrate: 11224 kb/s
06:37:49: Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x576, 25.00 fps, 7800 kb/s
06:37:49: Stream #0.1[0x80]: Audio: ac3, 48000 Hz, stereo, 448 kb/s
06:37:49: Assuming PAL for target.
06:37:49: Output #0, dvd, to 'D:\********':
06:37:49: Stream #0.0: Video: mpeg2video, 720x576, 25.00 fps, q=2-31, 7800 kb/s
06:37:49: Stream #0.1: Audio: ac3, 48000 Hz, stereo, 448 kb/s
06:37:49: Stream mapping:
06:37:49: Stream #0.0 -> #0.0
06:37:49: Stream #0.1 -> #0.1
06:44:41: [dvd @ 00410EB4]buffer underflow
06:46:18: video:4331106kB audio:377969kB global headers:0kB muxing overhead 1.960706%
06:46:18: Done: Processing assets for DVD creation
Authoring DVD Folders
06:46:18: Creating TitleSet # 1
06:46:18: SVCD2DVD: DVDfolders
Generating DVD folders please wait....
06:46:18: -->: DVDFolders creating VTS
06:46:18: -->: VTS 01
06:46:18:
DVD Folders: Processing D:\**********...
06:53:31:
06:56:34:
06:56:34: Finalising DVD...
06:56:34: SVCD2DVD: DVDfolders
06:56:34: -->: DVDFolders creating table of contents
06:56:34: scanning D:\SVCD2DVD_OUTPUT\VIDEO_TS/VTS_01_0.IFO
06:56:34: Finalising DVD...Done
06:56:34: Done: Authoring DVD Folders
VOB2MPG Correcting PTS values
By dvdmovie in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 15th Mar 2012, 16:06 -
Medieval helpdesk. What tech support was like in the middle ages.
By freebird73717 in forum Off topicReplies: 2Last Post: 5th Jul 2009, 00:05 -
Got a DVD plays correct, copies correct but refuses to write on a blank DVD
By cemman in forum Authoring (DVD)Replies: 16Last Post: 21st Jul 2007, 16:09 -
SVCD2DVD taking AGES to convert files.
By smileymyley in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 22nd Jun 2007, 15:53 -
How to compute the value SCR and PTS for encoding MPEG2 PS
By clebean in forum Video ConversionReplies: 0Last Post: 5th Jun 2007, 02:44
