when i play this video i get a picture but no sound. i downloaded that k-lite mega codec pack and still nothing this is the error i get
media player classic could not render some of the pins on the graph, you maynot have the needed codecs or filters installed on the system.
QuickTime Movie Parser::audio 1
Stream 1
Media Type 0:
AM_MEDIA_TYPE:
majortype: MEDIATYPE_Audio {73647561-0000-0010-8000-00AA00389B71}
subtype: Unknown GUID Name {0000736D-0000-0010-8000-00AA00389B71}
formattype: FORMAT_WaveFormatEx {05589F81-C356-11CE-BF01-00AA0055595A}
bFixedSizeSamples: 1
bTemporalCompression: 0
lSampleSize: 4
cbFormat: 18
WAVEFORMATEX:
wFormatTag: 0x736d
nChannels: 2
nSamplesPerSec: 44100
nAvgBytesPerSec: 176400
nBlockAlign: 4
wBitsPerSample: 16
can someone please help on how to fix this problem it would be great.
thank you for the help.
Results 1 to 11 of 11
Quicktime installed?
"Art is making something out of nothing and selling it." - Frank Zappa -
yes there is a quicktime alternative with that codec pack and i have installed quicktime 7 and still have the same problem. but if i use the newest version of nero it plays the avi file as an audio file in nero showtime.
Codec packs can do more harm than good. Figure out what you need and get that.
http://www.kiva.org/about -
ok i tryed gspot and in the container it says
File type:quicktime (.mov/QT)
Mime type:video/quicktime
then in the proposed codec solutions and tests box it says
rendering failed. the following error is reports by direct show
0x80040295 an operation fail due to a certification faiure.
the video i have it worked before my computer crashed on me. I had them back up on a cdr and now i want to watch them again and now they wont work. for the codec pack it was the same pack. I installed before for them to play and it worked. Now they updated the pack and it wont work. so does anyone have any other idea's? i installed quicktime 7 again to see if that works. and it doesnt work. -
i've downloaded the newest quicktime and installed it and it still doesn't work.
It sounds like Nero has kidnapped the file extension. You may need to go in Nero and unregister that extension. At that point, it should work fine.
Believing yourself to be secure only takes one cracker to dispel your belief. -
i unregistered it with nero, i have divx 6 installed. I installed Xvid and all windows media player does is try to download a codec, and it fails but the video plays.
Video Playing problem....
By Amirul Izzad in forum RestorationReplies: 1Last Post: 13th Dec 2011, 04:31 -
Problem playing a video
By bf4648 in forum Newbie / General discussionsReplies: 4Last Post: 12th Oct 2011, 23:36 -
a problem playing the video
By man4life in forum Newbie / General discussionsReplies: 6Last Post: 28th Dec 2010, 09:42 -
Video playing PROBLEM
By Mark03 in forum Newbie / General discussionsReplies: 1Last Post: 1st May 2008, 18:28 -
Video playing problem!!!
By Wladimir90 in forum Newbie / General discussionsReplies: 5Last Post: 13th Nov 2007, 15:43
