    Jul 2005
    UK
    What's the quickest way to cut an xvid or divx in half?
    I want to take an xvid or divx (or any other avi actually) and simply create two or more halves.
    I don't want to wait for eterneity while a program I use rencodes, decodes, codes etc.
    Thanks.
    OM
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Try virtualdub. I believe if you use fast recompress it will not reencode though I may be wrong.
  3. You could try Virtualdub as yoda313 suggested or VirtualDubMod.
    Set both video and audio to "Direct Stream Copy".
    Jul 2005
    UK
    just tried it.
    no good.
    it wants to take a long time decoding and rencoding.
    how do i get to the fast recompress facility?
    Jul 2005
    UK
    just tried fast recompress... can't get it to work.
    it still wants to take time.
    Dec 2004
    Australia
    Fast recompress as the name suggests still recompresses. As somebodeez said, you want direct streaming.
    Jul 2005
    UK
    thanks.
    that worked fine.
    took just a few seconds.
  8. Originally Posted by OM2
    thanks.
    that worked fine.
    You're very welcome
