  1. My friend had Advent Children on CD it was 360Mb and she got it down from a 700MB size..
    How do i do that . its 700MB and i want it smaller so it can fit on CD
    Also how do i get the subs to work with it. I do have the SRT file, just how do i get it on with the CD so the subs come up
    Thanks ^^
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Take it from the top.
    A CD is just a shiny piece of plastic - not anything to apply any special conversion method to.
    What is 700 mb?
    What do you want to put on a CD with subs?
    (700 MB is the normal capacity of a CD-R, so that shouldn't impose any problem per se)
    /Mats
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    If in doubt, Google it.
  4. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Oh, that! Then just follow the guide "How to make any FinalFantasy movie to fit a CD" guide left.
    No, just kidding. What kind of video format (bedsides round shiny disc) is it to start with, and what would you like to end up with?
    /Mats
  5. Originally Posted by Lesodem
    Why don't you just ask you're friend?
  6. oops i meant "friend"
    The size is about 699MB
    And i have a SRT File so how do i get it down to about 400MB so it can fit on CD and how can i get it on with subs. ^^
