i recorded a video with fraps i then encoded it to divx 6.0 using virtualdub and for some reason the audio is out of sync.
what can i do to correct this?
any help would be greatly appreciated.
thanks in advance
george
btw here's a link to the last 2 videos i recorded which both have the out of sync audio problem so you can get an idea of what i'm talking about.
1. http://www.combatsimulation.net/videos/nfsmw.zip
2. http://www.combatsimulation.net/videos/facility.zip
When viewing the clips in MPC and WMP, they all played fine. When viewing them in Divx Player, they were out of sync.
WMP was playing back at 59fps. Would suggest recording at 30fps instead of 100fps.
Also when encoding to Divx, encode the audio to MP3. Your file size would be less than half.
Hope this helps,
Chas -
hi chas, thanks for responding. would i be able to encode my audio to mp3 using virtualdub? and if so how do i go about doing that?
george -
george,
In VirtualDub or VirtualDubMpeg2 under audio, choose 'Full processing mode' and 'Compression' and select the MPEG layer3 codec.
If you're using VirtualDubMod, I don't know how to change the audio. Maybe someone else could explain.
Chas
How to Separate 5.1 Audio Channels? Experiencing Extreme Frustration
By Nicolai Philippe in forum AudioReplies: 7Last Post: 15th Aug 2010, 18:35 -
Experiencing problems with audio in timeline, any solutions ?
By Recco in forum EditingReplies: 3Last Post: 31st Dec 2009, 14:28 -
Experiencing lag on intense visual effects on LCD TV
By dzsoul in forum DVB / IPTVReplies: 23Last Post: 13th Oct 2009, 22:33 -
serious conversion difficulties!
By bigbadmateus in forum Video Streaming DownloadingReplies: 3Last Post: 28th May 2008, 08:32 -
Experiencing problem with dvp5140
By mancalledhero in forum DVD & Blu-ray PlayersReplies: 3Last Post: 16th Aug 2007, 22:10
