Hi Guys,
I have asked this question before but it was with avi and mpeg.
Does the new MP4 file (it is new to me) supports DD audio (means is it with 5.1 channels audio)?
Or is comes as regular audio (stereo)?
If so how to convert it to be burned on DVD and viewed by DVD Player??
Results 1 to 9 of 9
It supports 5.1 audio, but not AC3 if that is what you mean.
Most DVD players don't support mp4. -
Originally Posted by celtic_druid
AC3: Audio Codec 3. This was the original and more technical name for Dolby Digital. Replaced by marketing mavens when they realized that Dolby's name was not in the title. Some RF modulated, 5.1-encoded laser discs were labeled as AC3. Later versions were labeled as Dolby Digital.
Dolby Digital is the trademarked marketing name for Dolby Laboratories' "lossy" AC-3 codec. The common version contains 5.1 channels (five primary speakers and an LFE channel), but the format supports Mono and Stereo usages as well. -
mp4 uses aac for multichannel audio. Dolby helped develope aac and it is digital.
That said mp4 can contain basically anything as a private stream so you could use AC3 if you really wanted. Just don't expect it to work with current players/tools. -
Ok Now I have multiple mp4 files and I want to convert them to DVD so I can run it on DVD player.
How can I convert mp4 to DVD title with 5.1 channels audio.
Thanks -
Does your mp4 have 5.1 audio? If not then creating 5.1 sound is a completely seperate process since you would need to generate the additional channels.
I don't know if it has 5.1 or just 2.
Is it possible to tell me how to do in both cases?
Also how do I know if the file I have is 5.1 or not ??
Sorry for bothering with lots of qestions. -
Hi again,
I have an mp4 vid file with 5.1 ch audio.
How can I convert it and play it on DVD Player with 5.1ch??
Hybrid [x264/XViD - MKV/MP4] Converter Support Thread
By Bonie81 in forum Video ConversionReplies: 6Last Post: 8th Jan 2013, 03:53 -
DVD player with MPEG4 support cannot recognize MP4
By videohalp in forum DVD & Blu-ray PlayersReplies: 2Last Post: 29th Dec 2011, 07:42 -
Looking for a good authoring software that support using MP4 files to DVD
By LegendaryGamer in forum Authoring (DVD)Replies: 4Last Post: 10th Mar 2010, 16:04 -
do any of the major dvd creators support mp4 files
By Dr.Gee in forum Newbie / General discussionsReplies: 11Last Post: 26th Mar 2009, 10:36 -
FLV's new Mp4 support...
By doctorm in forum Software PlayingReplies: 13Last Post: 20th Feb 2009, 23:27
