Im wanting to experiment with some BW video footage to turn it into colour. During my research, I found this:
http://www.cs.huji.ac.il/~yweiss/Colorization/index.html
Theres a zip file to download and opening the readmes in Notepad, it says you can use this with your favourite imaging software. But I have no clue how to enable this. It also mentions metalab or something?
Can anyone explain more about this please? If I got it working, it would certainly help save time!
Results 1 to 11 of 11
you would have to write the software to use it .. it doesnt really exist ... it is a research paper ..
commercial colorization costs $$$ and/or you can attempt it by painting frame by frame with advanced tools like flint, flame or fury - or in combustion , shake or fusion (or red) which tracks pixels frame by frame ... those setups start at around 5000$ and up (and up and up) ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Ive got Combustion, just dont know how to use it lol. A tutor from university recommended it but I left the course, so I didnt get to use it.
you will need a course -- it is not beginner software
all of them are good
Originally Posted by BJ_M
still not a working program - but closer
I seem to remember another paper reported over at doom9. I think they actually had a working method. You picked 4 or 5 areas in a sample frame and assigned colors, and the program guessed at the rest of the colors in that frame and the rest of the video. (Of course to get it right you'd have to do a whole lot more work.The bad thing is it needed
MatLab to run.
http://forum.doom9.org/showthread.php?p=623022#post623022
How to put black colour on screen without re-encoding?
By swalih in forum EditingReplies: 6Last Post: 16th Feb 2012, 03:44 -
"Greenish" Black & White To "True(r)" Black & White?
By DeathStalker77 in forum RestorationReplies: 8Last Post: 30th Jul 2011, 08:39 -
black and white
By foofie131 in forum Newbie / General discussionsReplies: 2Last Post: 24th Mar 2011, 21:15 -
Colour Avi (or mpg) to black and white
By cawright1 in forum Newbie / General discussionsReplies: 2Last Post: 21st Oct 2007, 06:00 -
Deep Colour/xvYCC colour/x.v.colour confused consumer
By ArthurDaley in forum DVB / IPTVReplies: 10Last Post: 9th May 2007, 18:10
