Hi,
I encode targa sequences to dvd mpeg2 with Premiere dvd mpeg2 pal preset.I tried all high quality presets vbr, cbr... but same result, when i play the m2v file with mplayer, it plays fastly about end of the movie.
Forexample if movie is 10 sec,
it play the last 3 second in about 1 second.Exactly like i time stretched the part of the movie but i did not.
I tried to play with divxplayer but same result.
Sequences has not a problem.I searched alot but couldnt find anything with this problem, anyone has any idea? how can i solve this? Please help!
Thanks!
Playback of elementary streams is usually pretty quirky-jerky. You should multiplex the video with an audio stream to get a smoother playback. Some players like MediaPlayer Classic will let you drag and drop the video stream into it and it will automatically load up the audio stream(s) if they are in the same directory. Even still, that isn't the best way for playback, but it should roll much smoother than playing just the video.
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
All video playing half speed?!
By MJ Peg in forum Software PlayingReplies: 8Last Post: 2nd Mar 2010, 11:07 -
ffmpegX won't convert files due to "syntax error near unexpected token"
By JayEm in forum ffmpegX general discussionReplies: 1Last Post: 15th Feb 2010, 17:26 -
Problem, videos playing in half speed.
By jgib7687 in forum Newbie / General discussionsReplies: 4Last Post: 26th May 2009, 10:17 -
black video when playing back .m2v (premiere CS3)
By morr1s2 in forum EditingReplies: 2Last Post: 5th Aug 2008, 08:28 -
m2v file stops to display frames during playing
By Fendervr in forum Video ConversionReplies: 2Last Post: 22nd Aug 2007, 12:43
